New stove recommendations
Johnlh
3
Montana
Hey folks.
We are starting our build in SW MT this spring, and I'm looking for recommendations on new stoves. This will be used in a single level, 2700sq ft home, with radiant floor heat as the primary heat source. I've used wood stoves all my life, but only older, less efficient stoves. I'm looking for a non-cat stove that will be sufficient for our home, no soapstone. We would prefer a high quality pedestal stove. Most of the online reviews are for box store models. What else is out there?
begreen
Mooderator
Staff member
Nov 18, 2005
99,712
South Puget Sound, WA
The stove location, floor plan, and house design will have a lot to do with stove choice. Tell us a lot more about the house.
Johnlh
3
Montana
There will be a centrally located great room with cathedral ceilings, with 3 bedrooms all coming off of it. The stove will be located close to center of the great room. Ceiling and exterior walls will have 2in closed cell foam and fiberglass batt, so well insulated and sealed. SW facing, with lots of windows.
Like I said, the radiant will be our primary heat source, and the stove will be supplemental in the evenings or colder times. But I would like a unit large enough to keep us comfortable in case of power outages.
stoveliker
7,261
Long Island NY
And include what part of the house you aim to heat with the stove; 2700 sqft single floor will be impossible to heat with a single space heater (aka stove).
begreen
Mooderator
Staff member
Nov 18, 2005
99,712
Definitely go large. There are good choices from Lopi, Pacific Energy, Quadrafire, Ironstrike (Country line), in the ~3 cu ft size range. This will need ceiling fans or most of the heat will pocket up at the ceiling peak. Heating during a power outage might be challenging unless the cathedral ceiling is open to a loft area. That spot will be the warmest.
Reactions: Slocochef
Johnlh
3
Montana
I'll look into those. We have a few local fireplace shops around that usually sell nicer stoves as well. Ceiling fans are a must have, as we won't have AC either. We have a backup genny, but I absolutely despise writing checks to the electric and gas companies. We built a 40x60 shop, with a 4/12 pitch and 2in closed cell insulation. Currently heating with a Century from the 90s that is leaky as can be, but has kept us comfortable in -35 this year.
