I currently have a CFM 2500 insert (made by SBI, same as Century 2500) trying to heat a 2600 sq ft house and it just wasn't doing the job, even after installing a block off plate and filling the chimney with roxul, although that did help a lot. See here for that thread:
https://www.hearth.com/talk/threads...insert-not-really-helping-please-help.174273/
I did update the above post but was advised by another forum member to create a new post for the below.
Yesterday my dad and I drove down to pick up the Osburn 2400, about 9 hour round trip. I used an engine hoist to load and unload it in the back of the truck. This morning I cleaned out the insert and took the pictures.
It'll definitely need to replace some parts but looks to be in great shape. I would like to hear your thoughts. In the spring/summer, I plan on taking it all apart completely getting rid of the rust and painting it with stove bright paint, and replacing all the gaskets for next season. Looking forward to fall/winter already. I plan to document the insert restoration in this thread as it happens.
Glass and door in good shape, just needs a good cleaning and paint.
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241866-c944ff715427bcba6224e904010a6900.jpg?hash=NAEho-zWgj)
Secondary air tubes. The middle one is a little bent, is that okay to use as it or should I buy a replacement?
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241867-3b36725d4d9002e727e4725e739be5c5.jpg?hash=1bE930frs-)
Blanket weight and close up of air tubes:
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241868-5034a6d85fde8da938530dfa971b2f30.jpg?hash=5-Xca9vjQU)
The below was what was used for the top baffle "C-Cast Baffle". Very light stuff, like a very light firebrick. To replace these, I need two at $70 a piece. I plan on replacing them but was wondering if anything else could be used that a little less expensive? Also, there seems to be 2 kinds the below pictures, which seems to be vermiculite, cheaper at $40 each and a gray one. Any idea which one is better?
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241869-9ea8f28f76d79e1945175856a1efe3e0.jpg?hash=NblalkjViP)
Top of insert:
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241870-356b2d452a99015f06c2fbafd68224a0.jpg?hash=eL-3aTBCHh)
Pieces pulled from the inside. According to the manual some are for holding in the firebricks. the other metals pieces were probably used to level the insert when it was in fireplace and just thrown in when removed, I can assume.
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241871-8e578b4e5c933adeccf014e05e1fa353.jpg?hash=yT4YD3P8So)
Blower. It works and pushes a lot of air. Manual says "up to 144CFM". Looking forward to having a blower with a temp switch.
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241872-935ddcfb96558ef9d89d2ef3f408d961.jpg?hash=rCcBBVbaHv)
The back:
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241877-2205d77447967da14fc99e93a8a9fa47.jpg?hash=4j0AagkUQy)
Side. The air control is really hard to push in and out. Should I just put some grease to lubricate the moving parts?
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241874-cc4488cc1b203676bc5eeaf114e5e392.jpg?hash=c0YzJBy9_5)
The other side:
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241875-c1788ba577d1ded2975475e80875eddf.jpg?hash=XK5_qascJN)
It's the bigger surround that Osburn sells so I lucked out. This one's height is over 30". Seller wasn't able to measure before so I was hoping it wasn't the smallest one as it wouldn't cover completely my fireplace opening, but thankfully this one does.
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241876-d9c94844e38378c741173cff979cf92c.jpg?hash=RvxXoPKfb3)
Manufactured 10/13/2009. Newer than both my cars, and house.
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241878-1a506b0ed7aed115cfb168cce80a320a.jpg?hash=h7BWwLvvT5)
Good firebricks vs. the cracked ones. Do you recommend I buy new ones to replace the cracked ones or can I try and just fit them back together best I can? If putting them back together should I use a bead of that cement fireblock caulk?
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241879-fcb3cf5e96660c5ad13493e6a8a36f07.jpg?hash=7gQgxMZUC_)
Pieces to hold up the top baffle:
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241880-5762b475891f5d9e1d440afcdba7233d.jpg?hash=VQGKJVirP4)
Baffle insulation blanket, definitely needs to be replaced. $28 part or can I just use a thin cut of roxul?
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241881-d49aca2291c28a858313187d15428b33.jpg?hash=14A8o3802g)
Air gap picture. Any thoughts on how to clean in there? Or just leave it?
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241882-a82cafbc9c44b0f4c895096abe1b9889.jpg?hash=UiBLTM1w1L)
Door. I think the seller used the wrong diameter gasket (too small) as the door doesn't completely seal that well. either way I plan to replace it next season. Seems to be a pretty cheap part, like $25.
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241883-f7208d1ae578265948da1de258eb7ed0.jpg?hash=xQu7PtZdgg)
This firebox is huge! Over twice the same of what I have now.
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241884-033da4be8d911a742087394b4572a157.jpg?hash=R27hIQ1ejM)
Inside firebox looking down:
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241885-1590450d376a7924edf531cb11924c96.jpg?hash=S8ULFQNpCB)
In, looking to the left:
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241886-6a5bcc0aee3cc177a225924631172b0c.jpg?hash=CORGUYtEF6)
Top of insert:
The back:
The other side:
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241887-b7d4811500c2ee5f26d00f4ba14fff95.jpg?hash=QpGvMRaUoc)
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241888-4d9c430e8d4118967dde08f58b476453.jpg?hash=C1l_GSFpBk)
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241889-4c9d846855ba5161ba3a23870fe027c2.jpg?hash=R2tPh_CMHc)
![[Hearth.com] New to me 2009 Osburn 2400 Insert/restoration [Hearth.com] New to me 2009 Osburn 2400 Insert/restoration](https://www.hearth.com/talk/data/attachments/241/241890-abe4304de443cdb7a08c412d6a6a1408.jpg?hash=f4skQBbHol)
