Hi all. I am considering a Harman XXV as I really like the look of the stove and reviews seem really positive. However, I would like to know if this size stove would be sufficient considering the following floor plan...I am going to place to stove at the upper left wall on first floor as detailed below (left wall of family room/breakfast room/kitchen great room), either centered on wall (below tv) or in the upper corner. Are these good locations?.
First floor:
![[Hearth.com] New to pellet stoves, question about needs/size [Hearth.com] New to pellet stoves, question about needs/size](https://www.hearth.com/talk/data/attachments/140/140111-c836f706bc1d9d499c70c4a024468160.jpg?hash=mm9Tg01p5i)
Second floor:
![[Hearth.com] New to pellet stoves, question about needs/size [Hearth.com] New to pellet stoves, question about needs/size](https://www.hearth.com/talk/data/attachments/140/140113-8ed1da9dfb1a054dd5749a18e75a7da6.jpg?hash=X_-opRXnCk)
I currently heat the home with an electric heat pump, typically at a thermostat setting of 68 in the winter. Wife complains as the heat pump doesn't really put out a "warm" air and she constantly "feels" cold. I can't complain as to the cost of running the heat pump, as in WV electricity is relatively inexpensive. Sadly, I will probably never be able to recoup the cost of the pellet stove and install (approximately $4500 from what I understand) along with the cost of pellets (maybe 1-2 tons a year?) in comparison to the electric heat pump. However, the "warmth" the pellet stove will provide will be worth the added cost. As well as the comfort in knowing I can heat my house in the advent of a power outage (which occur at least annually for extended days).
Just wanted to hear opinions from the collective knowledge base here prior to going to the local installer for their opinion. Given the floor plans, would the stove heat the primary floor well? would the heat travel up to help heat the 2nd story? House is situated on a 9 foot solid pour concrete basement. I do not plan on heating the basement over what the heat pump now provides. House built in 2008 and relatively good construction, well insulated. Current electricity usage is around 15k kilowatt hours for the whole year, all inclusive. House is 2750 square feet plus 1250 square foot basement.
Thanks so much if you made it through this long post. I appreciate any insight as I am completely new to pellet stoves and would love to make the right choices!
First floor:
Second floor:
