Hi Guys! What a great forum. I've learned a lot over the past month, searching the site and reading many threads that have answered most of my questions already. I do have a few questions because I've read conflicting posts.
A little background: I have a 1980 Fisher Grandma Bear II or III with no baffle plate or pipe damper. 1600 sq ft raised ranch in the mountains of Sussex County NJ. Wood stove is in the finished basement. 8" flue, exterior masonry chimney, 22' tall, 8" single wall stove pipe. There was a face cord of very very seasoned hardwoods that came with the house. Unfortunately the previous owner is deceased so I can't get any info from him about the wood stove or its tendencies. My neighbor told me that the house was heated primarily with wood during the winter months. I have been reading a lot in the FAQ's and learning about proper wood seasoning, proper burning techniques, burn cycles, etc.
Since this is a pre-EPA stove I am going to check the chimney every few weeks to see about creosote formation. I've already had a chimney expert sweep the chimney and repair a cracked flue tile at the base of the chimney and he told me that this is a very nice stove and should heat the house quite nicely.
I keep the stove pipe temp in the burn zone while I am home and watching the stove (from 6pm-bedtime) and I have a few coals left over in the morning from the overnight burn. I get a fire going and then stuff it for the day (to leave for work @7am). I am afraid that the stove pipe temps settle in about 240-ish for most of the day because I only have about 25 minutes of the stove burning well before I close the air intakes (to about 1/2 turn) and leave for work. I have a wifi thermostat so I follow the temps via internet throughout the day.
Here are the readings from yesterday that I am getting from the wifi thermostat (on main floor outside bedroom #3) throughout the day (it was 25-32 degrees outside). I know the stove room is a lot warmer than the main floor and that concerns me that its getting too hot in the basement.
7am- 70 degrees
730am- 73
8am- 76
830am- 78
9am - 79
10am - 79
11am- 77
12pm- 76
1pm -75
2pm- 73
3pm- 72
4pm- 70
5pm- 68
6pm- 66
I haven't been able to come home (around 6pm) to any coals left in the stove. It is always cold and nothing but ash. It hasn't been an issue because the house isn't too cold (its about 66) and I get a good fire going in about 15 minutes.
My questions are...
1. How worried should I be that the upstairs is at 79 degrees (2 hours after I leave) I feel like it must be really really hot downstairs and I'm not there to monitor the burn?
Last night I burned a really hot fire and had the stove pipe thermo in the "overfire" range 700 degrees for about 15 minutes and then i turned off all lights to see if I could see a red glow but I didn't see anything.
2. Are these older stoves made to burn really really hot without getting red?
3. Is it okay to let the stove pipe temp get below the "burn zone" once the wood is burned down and it is just coals? I read that you are always supposed to have it in the burn zone, but I also read that it is okay for it to get lower temps if you are down to coals.
4. The splits that I have are relatively small for this large stove and when I load E/W I have a 2.5" gap from the wood to the firebrick on both sides. Would I get a longer burn time if I play tetris with wood and fill in all gaps, or will it burn hotter because I stuff more wood in there?
5. I also want to know how to get Bedroom #1 (see floorplan attached) warmer. When the stove room is about 85 degrees, the upstairs thermo (outside bedroom #3) is at 74, but bedroom #1 is at 65-66 and I can't seem to get it warmer. There is a grate in the hallway right outside bedroom #1 that is not shown in the floorplan. Should I put a fan on top of the grate and blow down into the stove room?
Thanks in advance for the answers and I look forward to interacting and being a part of this awesome forum. Sorry for such a long post, but all the threads I've read people always ask for as much info as possible.. so there you have it!
-Dave
7am- 70 degrees
730am- 73
8am- 76
830am- 78
9am - 79
10am - 79
11am- 77
12pm- 76
1pm -75
2pm- 73
3pm- 72
4pm- 70
5pm- 68
6pm- 66
My questions are...
-Dave
