The other think is that when dealing with cathedral ceilings, you have to consider cubic ft too, not just sq ft.
JRHawk and I have similar sized houses, but he has cathedral ceilings, I don't...between that, and less HDD here, I don't have to run mine as hard as he does.
That doesnt help at all...and where is the Kuuma placed in that 70'? Middle?
Heat loss to the ducts can be significant, especially if they run through cooler (or even worse, unheated) spaces...that can make a bunch of heat just "magically disappear" in a hurry!
When you bought the furnace from Lampa, did they say it would be able to heat 2800 sq ft in your heating zone ? @JRHAWK9 or @brenndatomu please correct me if I am wrong, but wouldn't that be at the high end of what a Kuuma could handle ?
I think the Caddy and Kuuma are "similar" in size. I'm heating a smaller house that has pretty good insulation and I have less HDD's than you do and there is no way it would be able to heat 2800 sq ft with temps below 20 - 25F. When temps are below 10F or so my Caddy can keep the house at 70 - 73F but I need to check it more often and usually have to fill it on a pretty healthy coal bed.
I brought in a wheel barrow of several years aged hard maple for the upcoming cold front, but that should last me weeks.
Talk about efficient! One wheel barrow. Weeks? Holy smokes
I think I understand way people give up on them now.
On who?
I've only ever personally heard of 2 people "giving up on them"...and they both openly admitted that they had big ole leaky houses and just didnt do their homework on what it was gonna take BTU wise to heat the place...the one went to a OWB then, the other back to gas (I think)The VF100
Yeah, they are up there where they are lucky to have the ice all melted by Memorial day, and to be able to swim by the 4th of July!I believe Daryl (the owner) has a 30 year old Kuuma heating his personal home way up in N MN where it's always COLD. I believe he's heating ~3,000SF (IIRC) and he told me he hardly has to take it off low. He admits though, his house is sealed and insulated very well.
I think there is something very basic being missed here and I am just trying to save you from a costly mistake.
I was a bit vague there, I should have specified the one wheel barrow of maple should last two weeks only burning it at night. I burn about a half cord a month (85% spruce and fir) cooking and heating. Sometimes on heavy cooking days I have to crack a window if it's not too cold. On a day above 40 df I won't light the Morso at all. I don't usually burn hard woods in the cooker, they take longer to burn and it's usually a waste.DamnTalk about efficient! One wheel barrow. Weeks? Holy smokes
About 20° daily average (~45 HDD's) is about when I can keep it on minimum burn and start to leave a healthy fire going 24/7 and load on, what I consider, a perfect amount of coals so the Kuuma goes back to pilot relatively quickly. In temps over 25°-30° or so I can't do that, the house will get too warm.
I've always wondered if it's a return air issue. When I played around years ago and disturbed my return air to the furnace, it made a HUGE difference in the ability of the Kuuma to heat the house.
The insulation guys just left and said there is not much they can really do to make it any much better. They said the best they could do was to inject all the walls in the home for about 10k but he said after you spend that and fix the drywall he said it wont have any "wow" differences. He said in his opinion the furnace is just under powered for the home.
no I all ready looked into it no one around here has even heard of a blower test.....Sounds like no blower door test or no thermal imaging? They just looked and did a visual assessment?
I think I would term it more like, too much heat loss that is overpowering the furnace. Looking back at just the quick IR pic you posted a couple pages back, I think I see lots of heat signature. If you had a qualified auditor available who could do a blower test or proper imaging, I think that would tell the tale. But maybe you don't?
Elaborate on the "disturbed" return air please!
Are you guys using warmed upstairs return air? Or cold basement floor air?
Then what is going on then? Its the same setup (minus the chimmny) the old one used...I am telling you there is no way a 2800 sq foot house could use more than 100k btu per hour unless you have the equivalent of a window open. I think there is something very basic being missed here and I am just trying to save you from a costly mistake. Think about it, what was the efficiency of the Clayton? 50% And it took 9 cords to heat. That sounds more like a mid 20k btu average over 180 heating days
ok! I'll call them right nowContact your local utility/power provider. If they have not heard of it..... You are really in the sticks![]()
They said they dont do that kind of stuff and they dont know of anyone that does. I also asked for electric use records and they said they only keep them for the past 2 years so no help there....Contact your local utility/power provider. If they have not heard of it..... You are really in the sticks![]()
They said they dont do that kind of stuff and they dont know of anyone that does. I also asked for electric use records and they said they only keep them for the past 2 years so no help there....![]()
Still not sure where you are exactly...North of Scranton? But here are a couple places that can probably do a blower door test...or know someone that can...at least they will know what you are talking about anyways!They said they dont do that kind of stuff and they dont know of anyone that does. I also asked for electric use records and they said they only keep them for the past 2 years so no help there....![]()
www.nepaconstructionservices.com
