Well its been awhile everyone. Winter is coming and its time to pick back up where I left off. (First topic here: https://www.hearth.com/talk/threads...-in-basement-of-early-1800’s-colonial.175056/ ) The short of it is I have a new Hotblast 1551E EPA wood furnace going into a unfinished, dirt floor, stone foundation basement with pretty low ceilings.
I took a chance before having to bust out a concrete slab and called the manufacturer about my clearance issues in the short basement. I told them what I had going on and they said I would be ok with my total ceiling height and top of door to ceiling height coming up short by 1-2 inches in this situation. The unfinished basement is around 36’ x 24’ with no walls with no insulation between it and the first floor. They said in this situation they would count the bottom of the first floor as the ceiling height, not the bottom of the two floor joists above the furnace. I already bought 1/2” durock to hang above on 1” ceramic spacers just to be on the safe side. I didn’t stop to think if I mount this to the spacers plus framing to hold it on the bottom of the floor joists, my durock heat shield will be around 9” closer to the furnace than the ceiling itself was before shielding. Most of it would be a 6”+ air gap though. Am I better off just not using the durock at all as long as things aren't getting hot? My clearance for total ceiling height is 75 5/8” when manual calls for 77” and top of door to ceiling 46 1/4” wanting 48”.
Next question I have is can a manual flue damper be installed in a 6” DVL length of stovepipe like you would normally on single wall? I have seen a video of someone putting a normal looking cast type in but it looked like they used a regular 6” kit and it was tight on the spring to turn it or something. Also have read on here talk about a few people using a 6” cast piece for the pipe with a 7” kits shaft? I have already bought DVL from stove adapter to ceiling box connection with a clean out tee and would hate to not use it all now!
I am also interested in hooking up a draft gauge (manometer?) permanently or with a quick way of installing/uninstalling. I believe my chimney is going to end up 35’ of 6” duraplus straight up, no offsets just a cap as far as restrictions after the DVL tee in the basement. I have a feeling I will need a damper on this now that I bought the pipe not planning for it. Any suggestions on what to get here for a draft gauge?
Last, what is a good burn gauge/stovepipe temp gauge for the 6” dvl? I have read a probe type but cant find information on a preferred brand or how to assemble them in the pipe for a fireproof seal.
Thanks everyone again for any help!
![[Hearth.com] New Wood Furnace Install (Part 2) [Hearth.com] New Wood Furnace Install (Part 2)](https://www.hearth.com/talk/data/attachments/247/247039-7b0e7fd5c7d937707ad9ad837cf9e1d1.jpg?hash=s8O3A0K5rc)
![[Hearth.com] New Wood Furnace Install (Part 2) [Hearth.com] New Wood Furnace Install (Part 2)](https://www.hearth.com/talk/data/attachments/247/247040-85c0d26dc441040d13fd53ac6d431611.jpg?hash=gNdgmbYb1m)
![[Hearth.com] New Wood Furnace Install (Part 2) [Hearth.com] New Wood Furnace Install (Part 2)](https://www.hearth.com/talk/data/attachments/247/247041-867c91636cfd5351b2c84d60c2deee34.jpg?hash=VIUy99oMB9)
![[Hearth.com] New Wood Furnace Install (Part 2) [Hearth.com] New Wood Furnace Install (Part 2)](https://www.hearth.com/talk/data/attachments/247/247260-cd6381c34f657bcc75208d57663dce28.jpg?hash=jTIQdOZk8t)
![[Hearth.com] New Wood Furnace Install (Part 2) [Hearth.com] New Wood Furnace Install (Part 2)](https://www.hearth.com/talk/data/attachments/247/247261-da8223f7c18f74c5201b15610bb6a00d.jpg?hash=Elh_X9J_MY)
![[Hearth.com] New Wood Furnace Install (Part 2) [Hearth.com] New Wood Furnace Install (Part 2)](https://www.hearth.com/talk/data/attachments/247/247262-91afc058862ed3bbae059cb804dd0056.jpg?hash=kjty90kfhy)
![[Hearth.com] New Wood Furnace Install (Part 2) [Hearth.com] New Wood Furnace Install (Part 2)](https://www.hearth.com/talk/data/attachments/247/247263-53e1c706b5e1157e6c201234d02ca3d5.jpg?hash=A5ZprRIlHe)
