BrotherBart said:Texas Boy and Dennis need to compare the structures they are heating with a Fireview.
Todd said:Here are a few soapstone stoves with ovens on top from across the pond. Look kind a familiar.
(broken link removed)
Todd said:Here's some more info from Tom.
Todd-
The new stove will have a reversible flue collar (top and rear) and also have a catalyst. We didn’t like the low burn characteristics without a cat, but with the catalyst the low burn is clean and long. It will have a number of new wrinkles in addition to the increased size and heat output. We plan to release more information about the stove in the next 3-4 weeks. Thanks for your patience!
Tom Morrissey
Highbeam said:Todd said:Here's some more info from Tom.
Todd-
Tom Morrissey
Music to my ears. Now if only they would come out with a thermostat.... I'm getting greedy but a guy can hope. Hard to believe that they would even consider a non-cat stove after reading how dedicated they are to cat technology.
Todd said:I also think the problem for Tex is the fuel. It burns very hot and fast. Maybe he needs to burn 1/2 loads with more air and reload more often to keep the stove up to temp and reduce coaling? If he's burning full loads it probably peaks real fast and cools down and still holds the coals for a long time but isn't producing the BTU's normal hardwood cordwood does.
wendell said:Todd said:Here are a few soapstone stoves with ovens on top from across the pond. Look kind a familiar.
That is either the strangest coincidence or something is going on here. Same name and the exact same looking stove?
But I REALLY like the Eclipse series. I'd put one of those in my house in a heartbeat!
Backwoods Savage said:Todd said:I also think the problem for Tex is the fuel. It burns very hot and fast. Maybe he needs to burn 1/2 loads with more air and reload more often to keep the stove up to temp and reduce coaling? If he's burning full loads it probably peaks real fast and cools down and still holds the coals for a long time but isn't producing the BTU's normal hardwood cordwood does.
Right Todd. The question here is not the size of area he is trying to heat, the issue is how long of a burn time he is not getting.
That 3-4 weeks sounds pretty good for more information on the new stove.
Slow1 said:Seems to me that with all that super dry wood there that Texas boy should be building himself a wood-fired electric power plant out in the back yard. Wouldn't have to worry about smoking up the place - dry enough to avoid that - then the electric power could be used all year for whatever.
Flatbedford said:Slow1 said:Seems to me that with all that super dry wood there that Texas boy should be building himself a wood-fired electric power plant out in the back yard. Wouldn't have to worry about smoking up the place - dry enough to avoid that - then the electric power could be used all year for whatever.
Maybe a big OWB with some kind of conveyor belt to load it with all that dry wood.
BrotherBart said:NOTE TO TODD:
Down boy! Down!
Todd said:BrotherBart said:NOTE TO TODD:
Down boy! Down!
Ha, yes it's killing me inside! I just might go camp out in their parking lot to be the first in line! :lol:
bjkjoseph said:i called woodstock last year,i told them this thing makes alot of heat...too bad its behind 2 inches of soapstone..i told them i wanted to make a steel top for it,and the guy on the phone went into the whole marvels of soapstone speech....the stove they make is a great design, the cat is right there easy to get at...the quality is unmatched...but if this stove was steel it would be much hotter....i hope the new stoves top fits the original fireview.
dreezon said:Did you get an idea what it's going to look like? I'm dying to know.
