Hello,
I'm a newbie, and I'm hoping someone can help me. I had a Drolet 1800i and ss liner installed and have been doing a few break in fires and am wondering about creosote, since a few attempts were not very successful. As far as wood goes, I've been drying some for a few months but know that I can't use that until next winter. In the meantime I tried my break in fires with some kiln dried birch that I bought from Meijer. First fire was very small and definitely in the creosote temps, maybe 200-250. The glass was smoky afterwards. Second fire, I raised it a bit and got to maybe 300-350, still a bit smoky on the glass. Third fire was good, maybe 450-500. no smoke on glass, no smoke on chimney, everything burned well, and I think the new smell burned away. This morning, thought everything was good to go, but smoked myself out of the room trying to make a fire. Can't tell if I put splits on too early (probably) before having a good roaring kindling fire. Anyway, lots of smoke, smoldering, etc. I freaked out and removed the logs that were not lighting and smoldering and put them outside in a pail (didn't want to just spew smoke out the chimney. This was the same Meijer wood I'd been using, so maybe user error was the problem and not wet wood? Anyway, to finally get to my question. These attempts that were smoky and not particularly hot probably resulted in creosote. Should I get the liner cleaned immediately before making more fires, or does it take a lot more than just a few dirty/ smoky fires to cause a problem? If I try again and make a good hot fire, can I clean up the liner? Anyway, thanks for all the help. Definitely a learning curve for the new guy!
