Hey all thought id stop in and say hi. Just hooked up my defiant 1945 vermont castings stove. thing is HUGE! I have a bazillion questions but will share what ive done thus far:
bought used off CL and refitted the following gaskets; doors and windows, griddle, ash pan door, and rear plate that sits in front of refractory but behind fire brick. also new fire brick.
had a local stove guy hook up my chimney, he used single wall black inside up to a triple wall connector and then 3 sections of 8" triple wall. Its just barely 15' of chimney, i think the least amount recommended for the stove.
I have a rear heat shield but plenty of space so i situated it 23" to the corners of a non protected combustable corner wall. That part is to spec right from the owners manual. Finally the stove is sitting on thick versailles slate tile mounted to 1/4" hardibacker screwed to 5/8" plywood flooring sitting on 2x10 joists. temps under the stove have reached 160 degrees coming from a rutland temperature gauge.
Stove temps at the time were 550-560 degrees.
my 2 questions and ones that are concernning me the most
1. In cat mode, with air control valve closed, stove still fires and runs 500 degrees. Is the stove capable of shutting down, or is it kind of like once its fired you have to strap in and hold on...
2. Chimney guy that installed it feels the hardibacker/slate tile the stove sits on is adequate heat protection for the wood beneath it but Im not satisfied this is true. Should I use a bottom heat shield and woluld even that be enough or do i need a UL listed hearth pad. I was hopeful to let the stove sit on the tile without any additional needs both for asthetics and further reducing the overall chimney height.
thanks in advance Im sure ill meet some nice folks here
