Hello, all. This is my first post--I'm new to this. Here goes...I have an Aurora wood burning insert in a masonry chimney. It is vented through an 8 in. home saver flex liner. The last time I had it swept I was told I had no damper. So here's my question. On the back of my insert is a stainless rectangle by 8 in. round adaptor. While researching online, I found a cast iron insert adaptor that would probably work on my insert. Is it possible to install a damper in the adaptor? Also, if I damper it down, since it's only an insert, will the gases and exhaust remain hot enough to not condensate up my 20 ft. high, 8 in. round chimney? Should it have been a 6 in. liner? Many questions...just want to do it right.
