Started my new Englander 17-VL today for the first time for the purpose of break-in in / paint curing.
Per specification I ran the first heat cycle about 300 degrees then let it die down to room temperature and now in the process of running the 2nd heat cycle which is just under 400 degrees.
Not sure why, but I do not see ANY secondary flames coming out of the tubes.
I have a very good draft with a 19 foot straight up flute and the have no smoke plus a very active flames, but again no secondary flames at all!
Could it be the break in temperatures are too low for the secondary flames to activate, or is my stove possibly defective?
I was looking forward to viewing the blue secondary flames I've heard so much about !
Thank you ! Note: the first 300 degree burn was with kindling wood and the second 400 degree burn was with compressed wood bricks from Canawick.
