Ok. My stove, an Englander 30NCH, is in the basement. I have 2' single wall pipe straight up, then a double wall 90, then 2 feet of double wall pipe into 1 foot of double wall supervent chimney that goes through the wall, then the supervent T, then 20 feet of supervent chimney up the outside of the house, with a 15° offset around the eave of the house, resulting in 5 feet of supervent above the roof to a rain cap.
Anyhow, I have very poor draft. Usually I get smoke in the basement when I start a fire. Once it gets burning, I do get a little smoke when I open the door. But I have a hard time getting the fire going, and very difficult time getting any secondary burn.
Also, for what it’s worth, I have a two-story house with two wings on it and the chimney is coming up the side of the west wing. I think it goes about 3 1/2 feet above the peak of the roof of the west wing, then the second story is about 20 feet away from that. So basically the top of the chimney is still about 2 or 3 feet below the peak of the main part of the house.
I know that the 2 90s will reduce draft and I believe that being below the highest part of the house will reduce draft. I cannot afford at this point to fix both. If it were you, which of the two would you fix? Replace the 2 90s with two 45s, or add another 3 feet of chimney to raise it above the peak of the main part of the house?
![[Hearth.com] Not enough draft [Hearth.com] Not enough draft](https://www.hearth.com/talk/data/attachments/217/217773-da237f51a2aa2cb6a2786fbd09b9ff67.jpg?hash=r6kK9CkOqw)
![[Hearth.com] Not enough draft [Hearth.com] Not enough draft](https://www.hearth.com/talk/data/attachments/217/217854-6fde131b69d51a45e643d2d98dcfc132.jpg?hash=0iFheqDWUb)
![[Hearth.com] Not enough draft [Hearth.com] Not enough draft](https://www.hearth.com/talk/data/attachments/217/217853-d0113a2024595171bd6906a01ccee6ba.jpg?hash=ENRHwpS-8d)
![[Hearth.com] Not enough draft [Hearth.com] Not enough draft](https://www.hearth.com/talk/data/attachments/217/217951-4c7dc80230f9d0e6411b9c2543df08f2.jpg?hash=sGmK6tyGmM)
