Hello all,
I have been reading posts on here for a while but can't seem to decide and need some advice. We have a 24x26 cabin in Quebec, 1 bedroom on main floor, cathedral ceiling (half of it is open loft, where we actually sleep). So 624 sq ft + 1/2 open loft = total around 936 sq ft. It is a recent build and well insulated, a part from the floor which is a concrete slab.
It is off grid and the only source of heating is propane stove (Napoleon GDS28) which puts out only 22,600 BTU's. It's a weekend cabin and in the winter it gets to -30F at times so waiting 24 hours for the temperature inside to go from 23F to 60F is a pain. And it won't get any warmer than 65-70F when it's -30F out
I was looking at getting a wood stove instead, since the heat rises easily and we sleep upstairs so it's considerably warmer upstairs than downstairs but i can always open the loft window.
I am considering the Osburn 950 (same specs as Drolet escape 1200/Deco Nano/Spark II) which has a 1.55ft box and up to 45,000BTU's. It should do fine not cooking us out in the shoulder season and i'd really have to fill it in the winter to pump some heat but not sure if it will go up to 6-7 hours of actual heat in the freezing cold days or it's really 5 hrs as the manufacture states (the box has a similar depth to TN20/Super27 but 2 inches less width)
My next considerations would be the PE Super, TN20 or Jotul F45 (which i find a little pricey but fine piece of stove)
I will prefer the N/S loading, overnight burns if possible!
Currently the Propane stove goes through the outside wall so i can use that hole once i sell the propane stove but i prefer that the wood stove goes straight up through the roof (a good 16-20 feet or so) and I'll patch the hole from the propane. I will get it professionally installed.
Do you think the Super/TN20/Jotul F45 will cook us out during fall and spring? I don't want to use any space heaters, the propane smells badly everytime i light it and we're trying to eliminate it all together. The wood stove would be the only heat source.
I know i need a lot of BTU's to get the place warmed up from freezing cold when we get there but would the super 27/TN20/F45 be too much heat during sleep and during fall/spring?
My profile picture is the actual cabin so you get an idea
Let me know what you guys think!
Will the Osburn 950 do fine 95% of the time or it's just not enough?
![[Hearth.com] Off grid cabin new wood stove recommendations? [Hearth.com] Off grid cabin new wood stove recommendations?](https://www.hearth.com/talk/data/attachments/293/293961-62f87acd10713b2d76bf29047a2482f7.jpg?hash=rR8PekQnEQ)
