16" is 'recommended,' but 18" fit fine. One or two 20" will fit inside the door area, but not in the whole firebox.I do think I need room for 20 inch logs, the Fireview is 16. . .
If there's a decent Fireview 205 on hand for ~ $1k, that's an easy choice, IMO. Highbeam measured the capacity of his Heritage as 1.5 cu ft vs. 1.8 for the Fireview.The Heritage is nice but not sure I want to spend $3K. . .
Lopi LeydenCan you give me an example of a modern downdraft stove?
What kind or area are you heating with the fireview?I always laugh when I read that someone thinks running a cat stove is finicky or difficult or complicated. It is as easy as shifting your car. Maintenance? Very little and takes only a couple minutes.
Thanks Northwinds and JH,
Most of the oak I'm cutting on my place and neighbors has oak wilt. The bark falls off less than a year after the leaves come off. It dries a bit just standing before I cut it. It gets a little punky unless I split it right away however. I have gotten ahead of it and hopefully stopped the progression with trenching.
By all the comments here it looks like I'm going to have to get a well respected stove that will run $2K or more.
That is still better than the cost of a cozy heat Z42 I was considering to replace the old ZC chimney torch. I expect to get more heat with longer burns too.
PS Northwinds, I'm near Portage.
Obviously I want to spend less time bringing wood in. . .
Dan,
In case you missed it, I replied to your private message.
You've said that you're heating ~ 1700 sq ft in WI, but you haven't mentioned the house's insulation/tightness. . .that makes all the difference.
selkirk metalbest of course twist together n bands no screws ..i prefer their stainless 6 id /8 od 2100 rated theyre are others who make this std to.. unless lining a exsisting chimney ..It's a 23 year old 1700 sq ft bi-level with 6 inch walls, new windows and good insulation.
Both levels have open areas with about 450 sq ft each. Bathrooms and bedrooms in other half of each level.
The open area upstars is living, dinning and kitchen with a cathedral ceiling. The stairs (2 sets of 7) are centered and the stove is going in the lower level across from the steps. It should and does currently get great convective movement to the upper level.
The south side of the house has an enclosed 10 foot wide deck with 4 ft windows down the entire 40 ft length. This deck /porch gets to 50 degrees on a sunny 25 degree winter day. The area under the deck is enclosed also for storage and provides a large area of trapped air to insulate the lower level along the same side. I have an insulated 2 car garage on the north side. I believe for a smaller home it is quite efficient.
Also we don't intend on never running the furnace but I am planning to burn 24/7 when below 25 or so.
I am hoping to be pleasantly surprised that I can heat the whole house with a stove.
I called the guy with the fireview in Milwaukee and it is a 205 model but one of the first ones built in 1996.
He has disassemled it, sand blasted the cast and repainted with paint from the factory.
He is willing to negotiate.
I also called Jeramy at Woodstock and he said to plan on buying a new stainless cat for $125.
I'm going to look at it and may offer a grand or less.
I'll let you guys know how this comes out and my next questions will be what I should use for pipe.
Thanks again for all the insight,
Dan
Thanks Tom dee. I currently have a triple wall galvanized running up a chase about 15 feet from ceiling in basement to outlet screen on the roof.selkirk metalbest of course twist together n bands no screws ..i prefer their stainless 6 id /8 od 2100 rated theyre are others who make this std to.. unless lining a exsisting chimney ..
I see much pleasantness in your future with a Fireview heating that space.23 year old 1700 sq ft bi-level with:
. . .6 inch walls.
. . .good insulation.
. . .new windows.
. . .south side of the house has an enclosed 10 foot wide deck with 4 ft windows down the entire 40 ft length.
. . .insulated 2 car garage on the north side.
I believe for a smaller home it is quite efficient. . .
I am hoping to be pleasantly surprised that I can heat the whole house with a stove. . .
Sweet!I called the guy with the fireview in Milwaukee, and it is a 205 model but one of the first ones built in 1996.
He has disassemled it, sand blasted the cast and repainted with paint from the factory. . .
I'm big on negotiating. Just keep in mind that the stove is worth every penny, if rebuilt right -- new gaskets + cement. The factory sells refurbs, now & then. . .last refurb FV sale I recall was ~ $1900 + shipping.He is willing to negotiate. . .I'm going to look at it and may offer a grand or less. . .
Yep, and if the seller didn't put in the new stainless cat, the stove probably doesn't have the new iconel screen for the cat(necessary to keep fly ash out of the stainless cat, which has smaller holes than the old ceramic cat.)I also called Jeramy at Woodstock and he said to plan on buying a new stainless cat for $125. . .
Class A pipe?. . .my next question will be what I should use for pipe.
Don't forget Aansorge's finder's fee.I'll let you guys know how this comes out. . .
We like pics!Thanks again for all the insight.
Update and a couple questions:There are many folks here doing just fine with class A running up the side of the house; class A is insulated.. . .I have read where Class A doesn't draft well when mounted outside running up the side of the house. . .
