I am planning on putting a wood stove in a cabin in place of the old stone fireplace. I have been looking at older stoves, pre-EPA ratings. The cabin is 2 br with loft, about 1000-1200+sqf, very open with exception of the bedrooms. The stove will be pretty much in the center of the cabin, or at least on the center wall and the cabin is not well insulated. (Ceiling R-19, walls maybe R-10) I will most likely use the cabin and stove 5-10 times (30 burning days) a year TOPS, mostly 2-3 day weekends from October-April. Here is my question(s).
1. Would one of the old workhorse wood stoves for $200-300 (Hearth Craft, Naushua, or comparable make) heat up nice an fast and do the heating trick?
(broken link removed to http://pittsburgh.craigslist.org/hsh/2189414316.html)
(broken link removed to http://pittsburgh.craigslist.org/clt/2201136850.html)
2. Only using it less than 10 times a season how often would I need to clean the chimney?
I guess the bottom line is I am not real worried about wood consumption. I am looking for something to heat up fast and stay hot. (Cast iron vs. steel) Many of the post I have read about the newer wood stoves is that they burn cleaner and use less wood......but do not put out the same heat as the old stoves. As I said the cabin is not very well insulated so I will need something to kick out the heat when it's 20F degrees outside. I plan on having a propane insert for some quick heat as well.
Or would I be better going with a newer stove? EPA approved?????
(broken link removed to http://pittsburgh.craigslist.org/for/2186166996.html)
Thanks in advance!
Thanks in advance!
broken link removed to http://nwct.craigslist.org/grd/2195971633.html)
