I am going to stick a wood stove ( portable cast iron with 2 removable burner plates on top that vents out the top) in the back of a truck bed that has a fiberglass camper shell on it. I intend to cut a hole in the top of the campershell and vent straight up through it however I could use two 90 degrees turns and vent out the top of the truck cab however I believe that it won't vent/burn properly? Safety is my #1 concern, price is my 2nd and life span is 3rd. I would like to go the stove store and buy the top of the line, state of the art, recommended components however that is just not gonna happen. Need to make this work on as little money as possible without compromising safety. I am a decent handyman and also DIY kinda person, when its feasible.
1. Least inexpensive way to shield the fiberglass from melting where the exhaust pipe will go through the roof?
2. Least inexpensive exhaust pipe that I can use? For my application I believe I can get away with single wall. The old rusty pipe was a single wall (steel?) pipe about 3 feet long and 6 inches wide. The previous owner said they used it in a garage setting.
3. Why would galvanized vent pipe that you can buy at your local hardware store for $8 for 6 feet not work? I believe its the pipe used in A/C units or indoor stove hoods. Is it so thin that it would melt? If its not going to melt then why not?
4. I said "galvanized," which might sound some alarm bells in some of you. I was reading an article that the wood stoves don't burn hot enough for the gases to emit from the vent pipe, unlike welding it, which would. The article even showed a modern article for a popular wood stove that included a galvanized exhaust pipe.
5. If I can't use the vent pipe I mentioned earlier then what is the cheapest I can get away with and where might I expect to find it?
6. Is 6 inch exhaust standard or can I get away with 4 inch?
7. Any other advice is welcome!! Thank you.
