Old Yankee by Lopi problem
TKRussell
11
New York State
I have a lot of experience burning wood. I'm getting older and took someone up on an offer for a free pellet stove. Yankee by Lopi.
I cleaned it out. Everything is clean. Changed the door gasket. Its a new vent. Duravent straight out the wall then up 5 feet outside.
-It rips through pellets faster than the auger spits them out. No matter what the "Heat" dial is set at
-The damper on the right (its a slide -pull in and out- mechanism) makes a small difference in the behavior of the flame. Not stopping my problem
-There's an exhaust damper on the left side of the unit that can be operated with a socket
-There is a gauge that tells how far the damper is open / closed. Its a horizontal slit in the sheet metal with a little metal tab sticking through it
-That metal tab is all the way towards the outside wall of the stove. As far as I can tell (from looking at literature I've found online) that means the exhaust damper is wide open?
-Should I mess around with the exhaust damper?
-Should I be looking at anything else?
Thank you. Hoping to be able to figure this out.
Reactions: Burnin Since 1989
Edit: Sooo... I didn't notice there is a reducer going from the 4 inch exhaust flange to a 3 inch. The manual calls for 4 inch. The old user was using a 3 inch vent system it would seem. Would explain why the exhaust damper is wide open. I installed a 3 inch vent to match what was coming out of the stove. Looks like I'm installing 4 inch
Got into the stove a bit.
-Took the combustion fan out. Cleaned that up.
-Flange that bolts onto the vent adapter was bent right up. Straightened that out.
-Screws that hold the flange to the fan were shot. Replace with bolts? Will add a pic.
-Exhaust damper was seized in the wide open position. Freed that up.
I'll keep posting here with my journey on bringing this thing back to life and my findings along the way
3 inch might be OK since you only have one 90 outside. Also it's a short run. What about OAK?
These are regular machine screws. If I did this I'd use stainless?
  • [Hearth.com] Old Yankee by Lopi problem
Reactions: ARC
They don't seem to use any stainless building pellet stoves. I'd inspect them after a few years.
How do I know if the 3 inch vent is going to work?
What temperature do combustion fans reach?
Can 500 degree rtv be used to seal the exit flange?
I hooked up my DDM to log what each number 1-7 represented in target ESP temperature. Here are my results:
1-251F
2-308F
3-343F
4-378F
5-411F
6-444F
7-470F
Above are temperatures recorded from a Harman P43
That probe is in the air stream of the combustion air.
High Temp Gasket Maker RTV is good to 650F.
3 inch is what all Harman's have. The size of the pipe depends on the length and how many angles.
4 Inch is always going to be better, but if you already have 3 inch set up, and your length/angles are minimum
it should work fine. If your manual and stove calls for 4 inch then it should be set up with 4 inch.
Your fresh air at 2 inch seems a bit small, but again if it's short it should be good. What is the size of the stove opening?
Reactions: ARC
Thank you for that information.
-I disassembled / cleaned / sealed the combustion fan housing.
-I used the Permatex red gasket rtv.
-The fresh air intake on the stove is 1 3/4". The OAK is 2"
-The flange at the exit of the combustion fan housing is 1.5 x 3 inches. Thats 4 1/2 square inches open for exhaust to flow through. 3 inch exhaust vent has 7 square inches to flow through. Not sure if that's how that works but seems sound enough for me to give try it.
When is the first test ? You are doing a great job!
