ansehnlich1 said:hmmm, great idea! easy way to get firewood into the house :bug:
LeonMSPT said:Long as there is no wind... (when does that ever happen, or last?) That tree shouldn't have been that mean to drop, depending on the top...
Start with a nice bottom side wedge where you want it to go... then make an inclined cut above the wedge, but nearly intersecting at the meeting point from above and in back.
If you want the tree to hang away from you, leave some meat over there. If you want it to hang closer to you, leave some meat close to you.
Big tree like that, I'd stop a few times during the cut to check the wind. It can come and go here in Maine in a heartbeat and it changes EVERYTHING. When you've got room and play enough, knock a wedge into your last cut behind your saw and drive it until it begins to gap, the "fall" has already started at that point. Just finish the cut and back straight way from the trunk, and watch it while you're moving, don't turn your back on it.
Never just sidestep to the back side of the stump... but as you move directly away, angling opposite the direction of the fall isn't a bad idea. Big tree like that comes down, it can do all kinds of weird stuff. Seen them ride right over the stump and slide, take you out if you're in the wrong spot.
mjbrown65 said:I bet his wife was impressed!
BJ64 said:mjbrown65 said:I bet his wife was impressed!
For some reason I think they sent her to go get more beer.
Stevebass4 said:this must be the guy's work truck
(broken image removed)
I still give him crap about that.Stevebass4 said:that wil buff right out![]()
fespo said:Did you notice the red " X " on the tree? To me, that means a lot clearing job. So the house, tree and everything else is probley going down. I could be wrong and that would not be the first time or the last time![]()
D/F said:...That happened right here in St. Helens, Oregon. And I work with that guys wifeI still give him crap about that.
