Some of you may have read my other post on my chimney damage........cracked terra cotta flue tiles using a masonry fireplace. https://www.hearth.com/econtent/index.php/forums/viewthread/5888/
I looked at some inserts and decided that's not what I want. I enjoy the smell, crackling, and poking at the fire too much for an insert. I know it's a big energy loss.
So I'm left with repairing the chimney.
Guy #1 (hired to sweep the chimney) - found a crack in the tile, didn't bother to go to the top of the chimney and inspect the rest, charged me for a full sweep, and shut me down. His estimate to repair with SS liner (not lined), cap, reseal smoke chamber, $2,900.
Guy #2 (hired to inspect) - very clean, very high tech. Sent a camera up into the smoke chamber, found a few small cracks, found several cracks in the terra cotta liner some of which were very large 1/2". Explained that there had to be a chimney fire at some point. Showed me the entire inspection on video as he was doing it and explained everything and downloaded it onto his laptop right there in my house. He explained he would either reline with SS and a slurry type of insulation around it, take out my old iron damper (I have a top sealing damper now), recoat my smoke chamber, and rebuild my firebox (some spaulding of bricks). He might consider relining the chimney with the rubber tube and poured liner method. Said the SS is ok, but if I had a chimney fire in the SS liner it wouldn't be SS anymore and would be subject to corrosion/rust. He said this would be an insurance claim because of the fire. His ballpark estimate $3,500-$4,500.
Guy #3 - (hired to inspect) - looked up the chimney, found the small crack, got up on the top of the chimney (via 2 step ladders instead of taking the extension ladder off his truck) and found the other cracks in the terra cotta. He said he would reline with SS, block off the bottom and pour insulation in from the top. He said my smoke chamber is ok. He went on to explain some downsizing of his business and letting employees go due to cost of insurance, etc.. He will call with a quote and mail a written quote.
Any advice would be appreciated.
Dave
Dave
