Other handy uses for a hydraulic wood splitter?
motoguy
Burning Hunk
134
Central MO
Just curious if any of you use your hydraulic wood splitter for non-wood splitting purposes. If so, what are those purposes? How good does it work? Mechanical press? Popping beads to change tires?
I'm just curious to see what ingenuity is out there, and what "I never thought of that!" things people do with their hydro splitter.
Went to use it to break a tire bead one time. The block of wood I was using under the wedge popped out and the dang wedge cut the rim. Never again.
I made a set if dies for my old splitter years ago to assist me when forging bigger stock when I was blacksmithing. or when I was doing pattern welded or Damascus billets. now I have a dedicated press for that.
We have used ours any number of times over the years to straighten, or bend, when repairing farm equipment. Latest was last winter when I straightened a bent 3-point hitch drawbar that had been abused. Usually requires making up a jig of some sort but it is very effective when parts are too cumbersome to put on the press in the shop or for repairs in the field.
I have used mine a few times for various things as posted up there ^. The weirdest was trying to split a beef in half.....don't ask.
Sounds messy...very messy.
I once saw one specifically built to be used for multiple purposes. Like any other piece of equipment they usually have a very specific function and there is always a compromise.
I'm just curious. I just purchased a DHT 35T unit w/ 4 way wedge. That's closer to a SS than I'd like to be, but I just don't think the SS is best for my needs.
I have used mine as a vice for resizing too long logs or branches. Clamp one end with the wedge, fire up the saw and bingo - makes for a nice and sturdy holder for that occasional resize.
One bead break on a lawn mower tire - not very handy.
A small form press brake for heavy steel (like putting a 90 degree bend in 1.5 x 1/2" bar stock).
And used to threaten an old boyfriend of the youngest daughter. It had to do with squishing squishy parts.
Like Notshubby said I have seen them used as a press for setting welds for pattern welding in the forge - I use a press when I do mine but it would be simple to convert my spitter to a press in the fab shop
Used mine to press a shaft from a very large cable pulley on my saw mill about a 2 inch shaft. This was a 6 inch piston
and pushed hard,when done found a set nut that locked it on that I didn't loosing up bad on me.
I split engine blocks with mine to take into the recycler. It's tough on the wedge, but I straighten it out every so often. Saves my back from lifting big blocks into my truck.
Reactions: Jazzberry
;lol;lol
I made a die and then tried to press sawdust into pellets or chunks for burning, not enough compression force to get the sawdust to bind. Might work if a binder was added.
Reactions: jetsam
Had an uncle and his friend that picked up small engines from landfill and the two old fellers would split the blocks and remove the steel and iron from the aluminum and sell at junk yard. They did well filling 55 gal.barrel drums of aluminum to sell.
Sounds like a lot of work. Why not add a screen and bucket to catch the oil pouring out for re-use too? I still recycle, but I think I lose money on it now.
Id like to use mine to rekindle the crush I had on my ex wife and her lawyer;lol
bob
I've used the splitter to break the bead on lawn buggy tires. It's an iffy practice and probably not very safe.
I use mine as a vice to hold longer bucks so I can cut them down to size. I've also used it to shorten bucks when I don't have my saw with me. I just line up the edge of the wedge where I want to make the cut and and pull the handle. 35 tons seems to always do the job.
I have a homemade splitter with some attachments, a pipe can press can crush cans into a long solid pipe block, I have a hardened steel wedge so I can shear steel stock, bend stock, take tires off rims by smashing the rim, shear tires into smaller pieces and lastly I shear a computer that was not working right, just for fun:) and many other things I have not tried.
