Good call. My truck would have shrugged it off, my foot, different story.Thank your lucky stars...on your toe would've been even worse.![]()
yes....but did you drop it on your toe?I went out on my porch bare foot to bring wood in and i dropped a split of wood on my big tow.![]()
Yeah i was lucky i did not brake my toe.Thank your lucky stars...on your toe would've been even worse.![]()
Yes.yes....but did you drop it on your toe?
I think i will put my boots on before going to get wood to keep from baking my toe.Tough crowd.
Same kind of wood i was very lucky it was not a split of hardwood.Did that once. Lucky for me it was a chunk of yellow poplar. Still hurt.
Wow i bet that was not to fun.I don't load my stove barefoot anymore, after an ember popped out and fell between my toes.
I have not had a coal to land on my feet yet. But i have a lot of burns on my arm because my gloves are not long enough.Ouch is right.
Anything involving the stove should be done fully clothed, as I've learned.
Went to load the stove one morning barefoot, and somehow a 1/2 dollar sized red hot coal came flying out and stuck to the top of my foot right behind the big toe. That sucker didn't want to come off despite the moves I was making and put me in a world of hurt for several weeks.
pen
Yup, that works.Used to see throbbing toes in the ER. Usually had a lot of blood under the nail causing a lot of pressure. We would heat up a paperclip and burn a hole in the nail. The pressure was relieved once the blood was no longer trapped. Sounds bad, but they always felt way better!
The hot paperclip gets through the nail without pressure. I have seen other methods, but anything that puts pressure on the nail hurts like hell until you get through it.Yup, that works.
Very small diameter drill bits, held in a small tap handle will work as well. It looks gross, but is painless to do.
Never tried that on a tow, though.![]()
