Looking for some advice. I have a Waterford Trinity MK2 in my basement. After a day or two of not running the stove cold air is pulled down the chimney and inside the basement. Forced air furnace and hot water heater are also in basement in a separate room, not sure if the blower fans on them is creating a negative pressure situation. When i crack the windows or door there is immediately a breese of air flowing into the basement. The basement is extremely air tight being poured concrete with only 2 double hung windows and a French door. Not sure of the best path forward, adding fresh air intake to the stove or having someone try and balance the forced air system.
