Hello
Last fall, I waited too long to bring the hose reel inside and when I did it was just about winter!
It was cold and when I tried to unscrew the hose from the faucet it was stuck tight!
I also broke the handle when I tried to free it! #$%%$#
So I took out the knife and cut the hose off just before the faucet and brought it in!
What is the best way to help prevent this from happening?
Here is what I did. The new nozzle is a luxury but wanted to try it out!
I purchased these parts from the local hardware stores.
16 oz Gaps & cracks great Stuff 3.98
Brass Quick Connect kit 5.68
5/8” female End hose repair 3.58
Flex Connect hose shutoff 7.28
½ x 6” long frost free shutoff 27.95
Union Dielectric ½ S ½ FTP 4.99
Copper 90 Deg Elbow FTGxC 1.79
Copper Stop Coupling ½” CxC 0.79
½” copper pipe x 2 foot 6.78
½” Brass Apollo HQ sweat ball valve 20.63
Little Big Shot Super Nozzle 8.97
Total 94.21
I cut out the broken faucet & inside shutoff and sweat in the new pipes to install the new up to code frost free faucet with new shutoff.
Replaced all pipes from the Copper T just under the blue handle shutoff ball valve. Then sealed the outside with clear RTV silicone and filled in the inside around the new faucet with Great Stuff expanding foam.
Now with the new union fitting if the faucet breaks, just the water to tehe faucet can be turned off, then it can just unscrew and a new one screwed back in!
The outside quick disconnect makes it a snap to bring it inside for the winter!
Pic 1 - Original Outside Faucet - broken handle and hose connector frozen to it!
The inside shutoff was too close to the outside wall so it all had to be cut out!
Pic 2 - Inside plumbing all done! Used TFE paste on Union to new faucet, and Had to sweat 9 joints plus apollo good quality brass shut off ball valve.
Pic 3 - New Frost Free Outside faucet all done with Flex connector and hose shut off plus metal quick disconnect
Pic 4 - New nozzle
Click on pic to Enlarge
Total 94.21
Pic 4 - New nozzle
