I have been thinking about power back up for my Harman P61A.
In looking in the manual, I see that the spec table on page 23 shows that fuse rating is 5A.
However, the wiring diagram on page 26 lists the stove as 480W 4.0A 120VAC 60Hz.
Furthermore, the wiring diagram shows a 6A glass fuse on the ESP control board.
I really hate it when a manual is not consistent.
So how much power does a P61A draw? I borrowed a power meter, and took some measurements.
When starting up (ignitor is on and the auger is running), the draw was 372W.
When the ignitor stops, and the auger is running and the distribution fan is on lo, the power draw is 128W.
With the auger is running and the distribution fan is on med, the power draw is 136W.
With the auger is running and the distribution fan is on hi, the power draw is 152W.
Without the auger running and the distribution fan is on lo, the power draw is 93.6W. So the auger is drawing about 35W.
Finally, in shut down mode, the unit was drawing about 46.1W.
Useful info if you want to size a UPS for backup.
Kenny
Kenny
