back of the stove is a good place to keep your temp probe[ if your stove has it]..The stove clearances in the manual I found online are a bit lacking for my simple mind. 13 “ from the corner of the stove looks like without the side plates, all the stuff behind must not get hot?
If it's not, you can spray paint it black. That's what the installer did with our stove pipe, and it's fine.They ordered a corner kit with the stove which I’m wondering if the inside pipe is black?
As such... painted to matchIf it's not, you can spray paint it black. That's what the installer did with our stove pipe, and it's fine.
my dealer here in eastern Pa sells theses which are the best softwoods around.Take is from a guy who "test burned" many a type of pellet stoves (Lennox, Cumberland, Hearthstone, Harman Accentra, plus a few more) more while living in WA ST........THERE IS NO SUBSITUTE, for Bear Mountain Wood Pellets. NO other brand even comes close. They are well worth the small premium you pay to burn them. I now live in NY and I can say the Harman P68 is the only stove I will ever own. I bought a used one (11 years old) for 1800 dollars (which is kinda high for a used pellet stove), used it one year and totally rebuilt it the next. The rebuild cost me 600.00 for parts and 8-10 hrs of my time. The stove is now as good as new and runs like a fine swiss watch.
just finished ton EasyBlaze softies from virginia. Those matras are softies from canada and there are 3 tons doug firs in background. Havent burned hardwoods in yrs. All my softies are very low ash and close to btu of the 9K btu Firs.bingo.......the purple bagged northern warmth are Bear Mountain in a different bag.....they are all i burn now. I used to burn Green Team pellets (which are very good) but the Bear Mountain produce about 75% LESS ash....and that is not an exaggeration.
![[Hearth.com] P68 install questions [Hearth.com] P68 install questions](https://www.hearth.com/talk/data/attachments/269/269191-aaf52607398aec856f3331c2f9ba653d.jpg?hash=fJZ1VxA-W9)
A conditioner for a generator is good idea, but doesn't address the type of waveform. You want either pure sinewave or a backup device using a modified sinewave that is APPROVED by Harman or you may end up damaging your stove.Good to know, I’ll pick up a conditioner unless there’s a better option. Thank you
How many folks are burning just one bag a day in a P68?
Now I know why I like my Enviro. Unless it isNever had a day with only 1 bag..
or lower I use1/2That's great if it's enough to heat your home. P68C input BTU is 67k and some change, with output BTU around 53500. Enviro Max INPUT BTU is 60000. So there's that...Now I know why I like my Enviro. Unless it is
really cold and windy -25or lower I use1/2
to 3/4 of a bag a day
Seeing as a pellet stove is a space heater mine an Enviro fe3That's great if it's enough to heat your home.
Burn 24/7. Can go thru 2 bags in 24hrs when super cold out. HarmanP61A. BIG burnpot..I should maybe point out, that I do not use the p68 when it is relatively mild out.
I use the NG boiler for those days.
I would guess that on thermostat, on a 42+° day, it may be <bag..
But I would guess not. On constant burn, on the lowest temp setting, and 3 feed rate.
it's a a little more than a bag..
They are a heat monster. Like to eat.
I get 24 hours on a bag on my Englander in the shop..
It would never heat my house..
Dan
For sure... same here..Burn 24/7. Can go thru 2 bags in 24hrs when super cold out
Should mention that the P61A is heating a 100yr old house that is not insulated.. doubleP windows but nothing in the walls. 2 floors so i think most stoves would use that or more in 20 degree or less temps including your Enviro. 8yrs of 24/7 and 1 ignitor replaced. Just sayin.johneh said:
So my point being simply, smaller stove, less heat, less fuel consumption. It sounded like there was something special about your model stove, like more efficient than many others, etc., but it's just less BTU than P68.
1895 house, here, just about same condition..Should mention that the P61A is heating a 100yr old house that is not insulated.. doubleP windows but nothing in the walls. 2 floors so i think most stoves would use that or more in 20 degree or less temps including your Enviro. 8yrs of 24/7 and 1 ignitor replaced. Just sayin.
sounds about right.. Am keeping main floor at 72 and upstairs 67 so our consumption sounds on par..1895 house, here, just about same condition..
Stove is in the basement. so actually keeping 2000sq.ft. warm.
Basement is usually 60-62°
Upstairs 65-67°.
40° day, colder night, takes a bag and a half..
Dan
