Anyone have any expierience with the Summit? Pros and Cons...
(broken link removed to http://www.chimneysweeponline.com/pacsumm.htm)
croghanite said:Anyone have any expierience with the Summit? Pros and Cons...
summit said:I've run Lopi, Jotul, and PE at the house, and the best by far is the PE
Mr. Kelly said:summit said:I've run Lopi, Jotul, and PE at the house, and the best by far is the PE
What specifically did you like about the PE over the others??? Were all other factors equal?
Anyone have any expierience with the Summit? Pros and Cons…
Jags said:Mr. Kelly said:summit said:I've run Lopi, Jotul, and PE at the house, and the best by far is the PE
Sacrilege I say! NOTHING is equal to the MIGHTY SUMMIT. **said with tongue in cheek**
north of 60 said:As long as you know a good welder with a mirror, have a case of baffle gaskets and the mechanical ability to set your new door for a proper seal, then your good to go. :shut:
Sorry, just had to. :zip: Is there any popcorn in the house?
P.S. All in fun
BrotherBart said:north of 60 said:As long as you know a good welder with a mirror, have a case of baffle gaskets and the mechanical ability to set your new door for a proper seal, then your good to go. :shut:
P.S. All in fun
I have a little time left. I will wait for the Blaze King stories in a year or two. :coolsmirk:
north of 60 said:Jags said:Mr. Kelly said:summit said:I've run Lopi, Jotul, and PE at the house, and the best by far is the PE
P.S. All in fun
iceman said:As long as you know a good welder with a mirror, have a case of baffle gaskets and the mechanical ability to set your new door for a proper seal, then your good to go. :shut:
P.S. All in fun
[/quote]We use essential cookies to make this site work, and optional cookies to enhance your experience.
