Palazzetti Ecofire Help, Parts & Service Manual
Phil Do's fire.
590
Hyde Park, NY
I post this every year for Palazzetti Ecofire Prima owners. I have igniters and pellet feed motors in stock direct from Italy. I also have a full printed or PDF version of the factory service manual with bulletins in print or PDF form. Have a problem Please email me for advice and fixes. My Ecofire just passed 26,000 hours and is still going strong!
Hello, I have have a Prima and it won’t run. Keep getting “low exh pressure” ? When I hold in the on button it goes through the “Final cleaning” with no problems pushing out the exhaust. Not sure where to start? Thanks for any help
Allen
Hello Allen, The low exhaust pressure is usually caused by one off three things. The top lid Not sealing tight. Is the gasket good? The top lid roller switch is out of adjustment. The front doors gasket or lower ash door gasket is worn out. Phil
thanks for the quick response. I have checked all the gaskets and they look sound. This stove only has about 500 hours on it. Bought a floor model at a stove place with no warranty. Didn’t know something that looks so well built would be such a lemon lol. I’m thinking about replacing the combustion motor while I have it by my workbench. When I try and run the stove and get the “low exh pressure” code, I hold the on button and it goes through the “final cleaning” stage and the exhaust seems to run full force out the vent pipe. Any recommendations where to find compatible motors for this? I noticed that the crossflow blower wasn’t working either. Motor is spent. I’ve exhausted trying to find any help from Palazzettti and the maker of the parts (Trial). I’m going to try and locate another manufacturer for that part.
You seem to be the only person that doesn’t speak Italian that even knows what a Ecofire Prima is lol. Thank you so much !!!!!!
Allen
Hi alan, the problem is most likely the little switch where you fill up the hopper. It's just under the door at the rear they come loose and go out of adjustment. It's a roller ball switch check it out it needs to go click when the door is closed all the way down. You can get a cross flow blower that is a hair smaller but works fine. A Piazzetta will do. There are two options on piazzetta's get the measurements and take get the smaller one . This also a guy in the Midwest that has the piazzetta blowers. East coast hearth is the cheapest. The floor models were the test units that dealers got at no charge. They were not supposed to be retailed. Mine now has over 28,000 hours on it, it wasn't a floor model and except for a one blower and auger motor, been great! Phil
Thanks Phil, your a life saver. I did know about the ball switch under the hopper lid. I know it does compress and will double check to see if it’s fully depressed when closed. Also, thanks for the info on the blower replacement.
Really appreciate all the help you’ve given me.
Thanks again,
Albe
Im
Also having trouble with low exhaust pressure. Happen to know if the ceramic exhaust pipe should have gaskets on them, seems to be missing.
Im
Hi Mperry - I believe the problem to the Low exhaust pressure error is an ash blockage at the clear sensor tube (located on the right side)
To fix this you need to remove the clear tube and blow out the tube with pressured air. Also make sure to clear out the connection fitting where the tube connects at the bottom. I hope this helps.
I'm interested in a igniter for my palazzetti Ecofire Prima. Let me know how I can order one.
Hello,
wondering if you can help, I have a palazzetti eco idris 14kw that has been throwing the error 'smoke temp alarm' and also 'water temp alarm' - it started with just the smoke temp alarm but now it also shows the water temp alarm. The errors come up very randomly, the boiler can be running for a few hours before it throws a fault?
Any ideas would be much appreciated. Thanks.
Hello,
Hello,
The smoke temp is the primary issue. Water temp alarm will set as a secondary fault. You will need to investigate why the smoke temp is too high. Most likely causes,
1. A partially clog of the exhaust airflow to the piping. The smoke chamber in the stove is an issue with these stoves. The only way to really clean is with compressed air. Blow in from exhaust fan opening out the side of stove, do not blow directly into the fan.
2. How is the exhaust piping? Any restrictions there? Clean thoroughly.
3. Worn out exhaust fan -combustion fan.
Please email me any other questions, my email is in several Palazzetti posts her in Hearth.com
Please get back to me if resolve the issue. Thank you!
Phil
Hey there, came across one of your posts where you mentionned you have spare parts and instruction manual. Could you send me a copy of the instruction manual PDF? Also could you quote me for an igniter, circulation fan and sealing rope for the ash tray? Thanks
Reactions: Albe33
Hello
We have a Palazzetti Ecofire Idro Anita and for the last few days the amber cleaning light keeps coming on at least once every day. We have cleaned the stove as per the instructions every time but it still keeps coming on. Could it be that the flue needs cleaning and is causing this warning or more likely a fault?
Thank you for any advice you can offer!
Looking for help, not sure if this is the right spot . I have a Palezetti Prima with at least 30000 hours on it. this has been a great stove. My exhaust fan stopped working yesterday. Can you get replacement parts for this and is it worth it for a stove of this age. Also how difficult is the replacement and access of this blower/fan?
Thanks
Reactions: Albe33
I've got the dreaded "low exhaust pressure" on my Prima again. Hoping Phil can save the day again. I found some parts in Great Britain but, they don't ship to the US. I'm guessing i just need a motor for the ventilator fan but not sure.
Hello Phil,
Thank you for sharing your knowledge on this topic.
I own a Palazzetti Lola 9 and I’m experiencing some critical trouble with it. The stove ignites normally, but after a short while the cleaning alarm (the orange sweeping symbol on the panel) starts blinking, and the stove shuts down automatically. The time between ignition and shutdown has been getting shorter and shorter, and now it shuts down almost immediately after starting.
Do you have any idea what the issue might be and how it can be fixed? Would you also be able to share the service documentation?
Thank you, I really appreciate your help!
Thanks
The exhaust fan on my Palazzetti prima was making squeaky noises, I only replaced the exact size bearing on the back of the motor and now still going strong after two years. You could buy the bearings from Amazon, the same number printed on the old bearing, invest in hi quality Javanese made, I hope this is not too late to help.Ty
