I just ran another startup and watched the light on the board marked igniter. As soon as the distrib. blower comes on the igniter light goes out. This is what always happened in the past but now the yellow wire (igniter air pump) stays hot. Ok a beer for real now and I'll check the wiring and esp tomorrow.
Right Jake, just sayin' it's not wired hot all the time because I can get it to stop.
Going by what you posted(highlited). Doesn't sound like the board is turning off power to the hot side of the circuit. Opening the door which opens the vac switch is only dropping the neutral side of the circuit. And the yellow wire remains hot. Tells me you do not have control as the vac switch will not open under normal operation. Do you plan on opening the door after the stove ignites?
Your board has an issue if the yellow wire remains hot and the igniter light is off.
Just saying, But what do I know! BTW the name is Jay FYI. I'm not a stove tech, But I did stay at a Holiday Inn!
Seems no problems with a Harman PC45 for some time other than Harman dropped the multifuel stove.
