Just fired up my new PE Summit for its break in burn and the draft seemed pretty weak. Couldn't get the stove pipe temp up above 250-300, had to open door to get it going well, never had to close down air control, smoke visible in chimney the whole time. Stove goes into chimney that must be 25 feet from thimble to the top, 8x8" tile lined, new chimney cap on the top. No draft issues when different stove was burned in basement last year, new stove is on first floor.
I did just put a flame to the gap between thimble and thimble adaptor and there is definitely some leakage in that area as flame is drawn in strongly. What should I use to seal this gap? Would just that make a big difference. Wood was good and dry.
Also, as you can see, my sweep put a 90 deg bend in when installing stove, not sure why, maybe due to clearance issue with wall near thimble, don't know how much this would affect draft. Nice breezy 55 degree day in Maine. Any thoughts are appreciated.
