I am having some trouble keeping the heat down on my PE Summit LE Insert with a 15' insulated liner. It's easy to control during the day, just loading 1-2 splits at a time keeps the temps between 600 and 300, measured above the door with an IR thermometer. However, my overnight burn is 5 large splits, and I cannot seem to control the rate of burn or the temp in the firebox.
I burn mostly ash, with some maple and black locust thrown in. My wood is around 12-14% moisture. I load my wood NS on top of a good coal bed, and leave the air control open until I get good flames. After that I slowly turn down the air control until I get sustained burn at the lowest setting. The temp measuring is usually around 400* when I shut it down. All of this is with the blower on the lowest setting. However, this doesn't produce a slow burn. The fire continues to accelerate until the front of the stove is measuring +730*! This is TOO hot for me, and too hot for a slow overnight burn. And the outside temps are still mild, around 35. I hate to think how crazy this thing will get if it were 15* outside.
What am I doing wrong? Am I letting the load get too hot before shutting it down? Should I load the splits and leave the air control low? Should I load EW? Am I being over-cautious? My last stove (a 70's slammer) ran away from me, and I do NOT want to experience that again. Any advice would be appreciated.
