6" liner ain't going to fit down that old stack. 5" or ovalized is the way to go. Going to be tough to insulate with only 6" ID of the existing tiles.
I believe Duraliner makes a ovalized flex also for the bottom, or if you want to fun full flex to top.
Ovalized may be more of a challenge to clean. They also make an ovalized double wall insulated rigid if I remember correctly.
Gaskets aren't too bad, but I made my own baffle gasket out of 3/8" rope gasket. The factory ones only last one season.
I now have the B series, and the baffle gasket is a bit different. I found some insulation board online and made my own baffle gasket for out of that, When I sweep it this next week or so, I'll see how that held up.
I lucked out and the flex dropped close to straight into the stove adapter, good thing for flex at the bottom, that's why I ordered it that way. If you can't drop straight to the stove, try a 30 degree elbow, or whatever works best for you.
