While I am still willing and able to heat with cord wood, I do see a day when burning pellets may be a better option.
I have been traveling to Biomass and heating Expos over the past several monts, I've found some exciting products and fuel sources.
Most of the high tech pellet burning equipment comes from Austria. The products displayed at the ISH Expo in Germany this year were quite incrediably engineered.
Dual fuel, cord wood pellet burners are becoming more common. Solafocus GmbH of Austria has a boiler that can self light either cordwood or pellets.
OkoFEN Heiztechnik of Germany had a condensing pellet boiler.n similar to condensing, furnaces or boilers, a secondary HX squeezes an additional 10- 15% energy from the flue gas. Flue gas temperatures in a common mod-con boiler run just above the water temperature the boiler produces.
Controls were touch screen on some products, lambda sensors, ODR and wifi control capability on many others. A few boilers actually generated electricity on-board with a small sterling engine. Keeps the boiler and pump running through power outages
At the NorthEast Biomass Heating Expo in NY, I meet up with Marc from Hydro-Heat. He had some wood gasification products on display, including a product for passive homes. This insulated stove puts about 70% of its output into the water jacket surrounding it, 30% as radiant heat to the space. He had a great looking stainless wood fired cook stove on display also.
Livestock manure as a fuel source ! Between turkeys, chickens, hogs and cattle we produce, or they produce, 2.7 trillion lbs per year of manure per year. Pellets are being squeezed from the manure, as well as many other wood and grass byproducts. Most of the pellet production in the US is shipped overseas. Companies from the UK and Germany are setting up large scale pellet plants in the US, with export in mind.
Here are some links and pictures.
www.pelletpros.com/id75.html
