Jacki1969 said:can anyone please tell me if I need to worry about any gases from my pellet stove if the power goes out?
eernest4 said:......If I were sleeping in the same room as the stove, i could wake up dead from trying to breath smoke.
actually , I would not wake up at all if I were dead,
but you should know what i mean........
Jacki1969 said:I just have the pipe going up our chimney,
I guess I will find out when and if it happens. I have been turning it off at night and using
the house heat to be on the safe side. Thanks for the replys![]()
eernest4 said:After proof reading, it occured to me , 2 other solutions to the problem of power outage & pellet stoves.
Computer geeks rave about a UPS, this is not united parcel service but rather an uninterupted power supply & is probably the only seamless solution to the problem; however, you need to get a ups with an inverter of more output that your pellet stove requires. Expext up to 30 minutes of run time from a ups & to have to buy new batteries every 4 years, if ni cad or every 8 years if lithium.
another answer is the $140.oo 2 hp 2 cycle 500watt @120vac generator from www.harborfreight.com
It wont stop the pellet stove from filling up with smoke but will allow you to restart the pellet stove and run it for another 8 hours or until the generator eats up all its gasoline, whichever occurs first.
And Worried If I Had Been Asleep OMG!!firewarrior820 said:this is what it should look like
www_godzilla said:Why a minimum of 5 feet of vertical pipe? I was going to put 4 feet up. Can someone explain? Thanks guys and ladies
MButkus said:If you have a lot of power outages.. get a $200 or so UPS. With just the fan on low, that size system should do at least 1/2 hour.
LT said:MButkus said:If you have a lot of power outages.. get a $200 or so UPS. With just the fan on low, that size system should do at least 1/2 hour.
Anyone think about installing a low cfm DC muffin fan at the exit of the exhaust pipe that would kick on if AC power was lost? At least it would vent the smoke in the event the stove power was lost so the stove would shut down in a close to normal fashion. That would also eliminate the need of you waking up and shutting down the stove. Might be a better option if power loss is somewhat of a rare event.
-LT
But you got to remember that several makes of pellet stoves have the "AIRWASH" system,(or similar) which is basically a minimal "gap" at the door/glass gasket. And THAT is a spot that would be very prone for smoke to enter back into the house during a power outage.PunKid8888 said:I don't think the horizontal bit at the top will effect it much. I am pretty sure the 5 feet of vertical pipe is just a number that seams to work good. I can't imagine anyone house filling up with smoke if they chamber is sealed well at the door gaskets and you have a warm pipe with some vertical section, the smoldering fire will still be hot and still want to rise.
I have had a bunch of power outages and not once Has my stove released a hint of smoke in the house. But I also have 6ft of vertical pipe.
If they have it vented up a chimney there should be no possibility of smoke entering the house unless its not fully sealed where the pipe enters the chimney.
