Question for all you heating and cooling experts. Tell me what you think and back it up with stats preferably.
I have a new heat pump that is rated 14 seer/8.5 hspf? I was wondering if it is more economical to run it during the 35-40 degree weather or the pellet stove? House is well insulated, and live in Wisconsin. I don't have any months to compare cost.
I eagerly await your reply. Thanks.
Unless you've got really cheap electric (mine is 18.5 cents/kwh) and really expensive pellets, anything under 50 degrees outside temp is starting to be more expensive to use the heat pump - and below 40, definitely. OTOH, you have to offset the heat pump electric use with the electric you'll use with the pellet stove - you can find that consumption (usually a few hundred watts/hr) in your stove's manual. You also have to factor in the use of your heat pump as a whole house central heater (which means all rooms are warm) vs. the pellet stove as a space heater (where only some rooms are warm) in your decision making.
