Northwest (OR, WA) Up over 20% - $290.00 Ton
Dataman
1,386
Newport, Wa
Asked yesterday at ACE Hw in Oldtown Idaho (Where I buy them). It's $290.00 per ton. Plus delivery charge (last year 90 bucks). I put in Cold Weather Heat pump and plan on not using pellet stove as much as before. I was switching over at 30f, now It's going to have to be -10f to switch over. It advertises 100% heating output at down to -13°F (-25°C) and operating effectively down to -22°F (-30°C), all with a Coefficient of Performance (COP) of up to 1.8. Midea’s EVOX G3 Heat Pump. So far it's great. Some minor hiccup with Electrical Panel. Bad Breaker and it was having problems running fan 100%. Sparking noise. in Panel had breaker replaced (2 of them). https://nahvac.com/product-category/evox-g3-ducted-solutions/
I have 2 Tons sitting and plan on just buying 1 ton. We typically burn 3 tons. Time will tell this next heating season.
Got it installed in April and it's very quiet unit the Compresser. 1/3 the noise. Inside fan noise is almost non existent. Temp out of Vent is 46f with over 20 degrees difference at return. We replaced Heat Pump from 2001. Trane XR13i that still worked, but for how long?
Reactions: vinny11950
For me, if pellets are $350 per ton, oil has to be well below $2 per gallon to be about the same. That said, if oil were around the same cost, or even slightly cheaper, I'd still use the pellets over the furnace. We love the toasty warmth of the stove in our living room and kitchen in the winter. We wouldn't be able to have that extra warmth with the oil furnace.
