My home currently has electric wall heaters... We are looking at either a pellet stove or a gas stove. Our home is approx. 1200 sf. Which would you suggest. Which is more cost effective?
rxygal777 said:My home currently has electric wall heaters... We are looking at either a pellet stove or a gas stove. Our home is approx. 1200 sf. Which would you suggest. Which is more cost effective?
eernest4 said:Pellet stove is the easiest, lest work and cheapest form of heat.
$ 5.00 for 40 lb bag of pellets,Walmart,home depot,lowes, last 1 or 2 days as primary 24/7 heat, depend on outside temp, last 3 day to 1 week as secondary heat, depend on outside temp.
Can be installed in any room with a clear outside wall to place stove up against,actually 19 inches out from wall.
$5.00 at $3.oo /gal buy you 1.67gal/fuel oil or 1 hour heat with 1.6 gal/hr nozzle on oil burner;
compair to 24 hours" fully on" pellet stove or 2 days 1 hr on, 1 hr off.
This duuuu,no brainer, like hondyaia car adds.
Tailrace said:During the heating season my furnace uses 5 gallons of fuel oil a day, and at the current rate of $3.05 a gallon, that's $15.75 a day. Since I bought my pellet stove I'm getting about a day and a half out of a bag of $4.75 pellets, which equates to $3.16 a day. It's not too awful cold here, so I'm planning on going through 1 bag a day when the chill really sets in. The difference from spending $4.75 a day to $15.75 a day to heat my house is incredible to me....especially when my house is toasty warm and in the 70 plus degree range, as compared to barely 68 degrees and my feet cold with the oil heat.
Hammerjoe said:I have a question about the calculator:
How is the annual cost calculated?
Sorry...but I wasn't out to try and fool anybody. I was just calculating the difference in cost from fuel oil to pellets from where I sit...and I never claimed to be an engineer. I'm pretty new to this site and i've never read anything on the BTU discussions. My furnace is definitely inefficient. and until my landlord decides to replace the dinosaur I see it as I'm saving money heating the house i live in.Webmaster said:Tailrace said:During the heating season my furnace uses 5 gallons of fuel oil a day, and at the current rate of $3.05 a gallon, that's $15.75 a day. Since I bought my pellet stove I'm getting about a day and a half out of a bag of $4.75 pellets, which equates to $3.16 a day. It's not too awful cold here, so I'm planning on going through 1 bag a day when the chill really sets in. The difference from spending $4.75 a day to $15.75 a day to heat my house is incredible to me....especially when my house is toasty warm and in the 70 plus degree range, as compared to barely 68 degrees and my feet cold with the oil heat.
This kind of "savings" is akin to how big a fish you caught might have been, using your hands spread apart to describe it! A BTU is a BTU is a BTU.
If the same exact stove was fueled with natural gas, oil, LP or ANY other fuel, the savings would be similar.
Maybe your furnace is defective or inefficient.....you can't compare apples to apples that way.
To compare the fuels as you claim:
5 gallons of oil - 700,000 BTU input
28 lbs of pellets per day - 250,000 BTU input
A Natural Gas stove at $1.50 a therm, would use about 2.5 therm a day if you replaced your pellet stove with a gas stove. That would cost less than $4 a day. Consider the original cost, the electric the pellet stove uses, the yearly service and the hauling of tons of pellets.....and I would suggest that the two are approx equal (if that). BTW, the gas stove works without electric at all, so can serve as a backup when the power is out.
We have discussed this DOZENS of times before. You cannot fool mother nature, and at Hearth.com you cannot fool most of our educated users - but you CAN fool yourself, which is fine and dandy. But just don't expect to get hired as an engineer.
So, new Mantra - "A free standing stove burning any fuel at approx the same efficiency and BTU input will do the same job"
