i went and looked at a few stoves today. very undecided about alot. what type of stove to get. if i want an ash pan. if i want to install myself. i am very handy and i do under we are plaing with fire. i guess i cant go with a used stove do to epa regulations has to be the new epa laws as per my local laws. i was going to find a nice used stove. and advice guys and gals. stove has to heat 1400 square foot. its on the basment its half underground. amd i will have vents with fans on them to pull heat up . it does not need to be a pretty stove just a basic model. i was looking at lopi stoves today they are a nice stove problem being that they are the only dealer in my area and i was reading they dont do internet sales on parts. jotul stoves are nice was looking at the f500 . i am not sure if i should go with a nice homedepot stove since its my first stove. not sure what to do . thanks for reading my rambeling mess lol.
Random thoughts . . .
If I am reading this post right . . .
Ash pan: There are pros and cons to ash pans. Some folks have stoves that have them and they love them. Other folks have stoves that have them and hate them. Some folks don't have them and are fine with it. I sincerely believe part of it is whether you grew up or are sold on the idea of an ash pan . . . and the other part is if your experience with a stove is one where the ash pan works well . . . or does not. I like the ash pan in my stove, but other folks with the same make and model say they never use their ash pan. It's all good . . .
Self installation: Making a hearth, installing the stove and chimney can all be done by a person who is handy with tools . . . just be sure your insurance company permits this. In my case there was no increase in the insurance premium, but the policy did state that I had to have a professional install it and sign off on it.
Types of stoves: The long and short of it is that there are a dizzying amount of choices to make. Steel, cast iron or soapstove stove construction. Secondary burner or catalytic stove to achieve cleaner burns. Sizes . . . the best advice I might offer is to see what designs you like and what are sized for your home . . . although if this is in the basement (and especially if the basement is not insulated) I would go larger than what you calculate you would need for your space (personally I like having the stove in my main living space where I can watch the flames and get the most benefit from the heat.)
Lopi,Jotul, Home Depot stoves: Lopi and Jotul stoves are generally considered to be quite nice. Many of the stoves offered at Home Depot, such as Englander and Summer's Heat, are more inexpensive, but are also quite popular here among our members. I think stove brands like Lopi, Jotul, etc. tend to be a bit fancier and higher end, but the cheaper Englander stoves found at Lowes or Home Depot are just as good.
Not sure if any of this helps you out . . . but by all means, stick around and if you have questions, post up your questions. Folks here are more than happy to try to help.
P.S. Don't forget to also look at the cost of the chimney as the chimney is just as important as the stove.
P.S.S. And just as important as the chimney and stove is the quality of the fuel. Garbage in . . . garbage out. Well seasoned wood = happier and warmer home owners. If you don't have your firewood yet, I would encourage you to get your wood sooner rather than later since many a person here has discovered when they order "seasoned" wood in the Fall that the wood is far, far from being seasoned enough to burn in a modern woodstove.
