When I've stalled a cat, it's usually been from getting too greedy with turning the stat down a little too far. I had a good fire with cat active turned it down too much, come back hours later to find cat inactive and a bunch of unburnt wood. Only done it a couple times.
Interesting post! I assume (with the BK anyway) that it would mean cat thermometer got to active zone. You closed bypass door. Cat thermometer came back out of active zone.
I use the term for both of these situations, or more generally speaking, anytime the cat goes active and then drops back out of the active zone before it should. Usually caused by closing bypass or turning down stove too soon, before adequate moisture is baked from your fresh load of wood.When I've stalled a cat, it's usually been from getting too greedy with turning the stat down a little too far. I had a good fire with cat active turned it down too much, come back hours later to find cat inactive and a bunch of unburnt wood. Only done it a couple times.
Regardless of baking moisture out, adequately charring the outside of the wood is what I find to be most crucial to avoiding a crash.I use the term for both of these situations, or more generally speaking, anytime the cat goes active and then drops back out of the active zone before it should. Usually caused by closing bypass or turning down stove too soon, before adequate moisture is baked from your fresh load of wood.
Ok, the consensus above works for me. Followup question.
Let's say I load the stove, get it hot, get the cat engaged, let it run a little bit, turn it down to say half throttle and go to work. I come back 6-8-10 hours later, I see a clean plume, or nothing visible coming out of my stack. I come in the house, through the stove window I see a bed of glowing coals and the cat is in the inactive range.
I open the door, pull the coals forward, break them up a little bit, close the door. After a while the cat is back up in the active range, without me having added any fuel. I engage the cat, and the cat takes off.
What is the term for that? Normal operation? Stalled burn? Other?
I would say that's normal operation no stall. You had a good burn all the way to the coaling stage. You sped up the coaling stage and got more heat out of it by stirring it up. If you were to leave it alone it would still probably burn 99% of the coals. It would just take longer and have less heat output. A stalled cat if you were to leave it alone you would eventually have a cold stove with splits left.
the area downstream of the cat was as clean as you could ever want a stove and chimney to be.
Lol... not THAT clean! But, 2000+ F on the cat does have a way of cleaning things out. Outside of single-wall pipe peaked at 450F during that event, but usually cruises at 250-275F.Same thing I hear from people that have had a chimney fire![]()
. Yep, I came home to a stalled cat 3-4 splits all on the right side, stacked high. WTH! I didn't even realize till later what happened when she told me she was roasting out at 88 deg downstairs in stove room.Another definition of stalled cat= wife too hot during the day, instead of turning off blowers and slightly turning stat down she cranked it down. Yep, I came home to a stalled cat 3-4 splits all on the right side, stacked high. WTH! I didn't even realize till later what happened when she told me she was roasting out at 88 deg downstairs in stove room.
