Please help, need to load heavy short logs...
Ram 1500 with an axe...
2,327
New Jersey
I have access to 100 pieces of 6-8 foot long black locust and red oak, besides cutting at site, how else can I load them into pickup truck to process at home? They are large diameter and very heavy......
Thanks......
Hire a log truck with crane arm for a few hours. That or build some pully lift contraption, or maybe a winch and a ramp.
Thanks......
buck em down to splitting lengths....and get some buddies and Buds ..... If ground has grade..park downslope and ramp em on the bed...
just finished doing that on a nasty slope by myself, bucking 20" round , 19" long blackbbirch..2 cords total..some I had to split in half on site and then load up...got old quick
if u find a way to load them whole...have a way to unload them as well..
on my old truck I had a backrack and I did winch some up on 2x12 ramps....would not reccomend unless that rack is triple duty bolted...and even then..
good luck man. And be careful
Scott
Reactions: pen
To get a log into a truck, I'd think about an electric winch and a ramp. Maybe take off the tailgate so as not to damage it.
Others ideas of the top of my head:
Block and tackle.
Rent skid-steer or tractor with pallet forks.
Utility trailer (side loader so you can roll them up with ropes or winch).
Hire timber truck to load & deliver load.
Rent large dumpster, fill it, have dumpster drop it off at your house.
Of course, available time and wallet will eliminate some options.
Sorry. Every time I hear "loading logs" I think of this video.
Now I know why......
Block and tackle.
Thanks for ideas....
Scott
Thanks
I use 24 inch logs so the rounds are heavy. I cut mine to half or thirds to make them handle easier.
[Hearth.com] Please help, need to load heavy short logs...
I just bring a 2x10 plank and roll single rounds (I buck to 20" lengths) up the ramp into the bed. That said, I'd be looking for a tandem axle trailer with drop tailgate and a winch for loading 100 large logs from a single site. That could take you a few weekends, moving one round at a time.
These are someone else's pictures. I think I took them off this site a few years ago. Anyway, when I can't do it the young-man's way anymore I might build one of these:
[Hearth.com] Please help, need to load heavy short logs...[Hearth.com] Please help, need to load heavy short logs...[Hearth.com] Please help, need to load heavy short logs...
I've pretty much stopped trying to load and move large logs or large bucked rounds. Instead, I bring the splitter and split them on site. The splits are easy to load and usually also result in one or two less times to handle the wood.
Reactions: Knots
This is why pick ups are useless for many things. Get a trailer with a ramp. Cut them to the size you can roll them up into the trailer.
As someone who processes WAY more wood than 99% of this forum, I'd not go so far as to say pickups are useless. They're limited, but I wouldn't be without one. I haul 1/2 cord at a time in my pickup, many, many times per year. When I have a cord or more to move, I grab a tandem-axle trailer.
Trailers are pretty useless where there is limited room to maneuver - which is most of the places I cut wood
Double axle dump trailer. They are low to the ground and can carry quite a bit of weight, I use ramps to roll them up into the trailer, only having to load once is nice, dump it when I get home. Cut the pieces down to whatever size you are going to split them, remove any of the limbs so they roll "easier".
I have tried splitting on site and I would rather buck them up and do the splitting at home on my own time frame. Getting the wood into my yard is my first priority sometimes.
Reactions: Roundgunner
If you can get someone to pick them up and deliver them for even a few hundred bucks, that is probably worth all the hours and effort you'll spend bringing them home.
Reactions: TreePointer
