Plywood termal buffer tank?
Andrew Robinson
30
Yellowknife NT Canada
Good morning,
I'm working with a remote lodge that wants to put in a Woodmaster Flex-fuel 60kW boiler - the model that can burn either pellets or cord-wood by just switching the grate. It runs at atmospheric pressure.
The lodge is only accessible by twin-otter or helicopter ... so the local Woodmaster Rep has been suggesting we build a thermal buffer tank on-site using an insulated plywood box, strengthened with a solid lumber frame & with an EPDM liner.
The other alternative would be to use 3 x 220 Gallon tanks, which should fit in the airplane & also in the basement space we have available.
Anyone had experience with such "on-site manufactured" buffer tanks? We are in northern Canada (NWT) - would any codes apply to these buffer tanks that would be hard to meet?
I have seen this done in remote homes that get water delivered by truck - one tank I saw was over 6 feet high and at least 10 feet x 10 feet - made with 2x10s & plywood.
Andrew
Tom In Maine - forum member on here - is the guy you want to talk to.
EDIT: And can't imagine any codes giving you problems. They were a non-factor for me.
Here is his website. I think the liner material is key.
(broken link removed to http://www.americansolartechnics.com/products/heat-bank-storage-tanks/)
A company in my area built dozens of lined, insulated plywood tanks. If you can build it in the corner of a basement you get that added structure to work from.
These were plywood with 2X4 on edge frame work. Similar to how you form plywood for a concrete pour, with 2X on edge.
Tom, mentioned above has nice knock down tanks that could easily be shipped and assembled on site. possibly less $$ than building your own custom tank.
