I just installed a 24' above ground pool that came with the works, sand filter, pump, chemicals, etc. When the pool first was filled, I didn't know anything about sand filters or pumps for that matter and set the filter to pool. I now realize I should have back washed and rinsed before starting. Anyhow, I vaccumed the pool in pool mode and after looking things up I realized I sold have been in filter mode. The problem now is, whenever I vacuum the pool (it's in filter mode), small flies and debris will come out of the output of the pool. It was a 19" sand filter which says it takes 150# of sand, but came with 100. After adding another 50#, I'm still having the same issues. The water is crystal clear, but I keep seeing stuff coming back out into the pool, which is clearly large enough to be filtered. Any ideas?
