Well, Detroit has been known to be full of it.
The digested sludge makes a very good fertilizer too. I'm thinking of trying it out this year.
A large farm west of here uses sludge on hundreds of acres. The road I used to use to go to work runs through the farm and it was an olfactory adventure every morning driving to work in warm weather.
Would that be GroCo or does your county have another product? How and where is it sold?
24/7 with a fresh pile
Ontario has strict regulations for human sludge on farm lands. It can only be applied once every few years and crops cannot be grown for human consumption after applying. Not sure on the time limit for either of those. Human sludge is chock full of bad stuff from prescription drugs to heavy metals that industries still flush into the sanitary sewer systems. Cooking it does not get rid of the heavy metals.A large farm west of here uses sludge on hundreds of acres. The road I used to use to go to work runs through the farm and it was an olfactory adventure every morning driving to work in warm weather.
Doug - this was also my understanding. There is a similar plant several miles from me but they do not recommend using it for gardens or any human consumed farming. Maybe there are different processing methods??
OK, this sounds like sewage sludge, similar to Milorganite. The stuff that comes from an anaerobic digester does not smell, it's been predigested. They mix it 3 to 1 with sawdust and compost it. The result is a great fertilizer with no concerns of pathogens, heavy metals, etc..Many cities have their own treatment plants. I am finding the fertilizer at the City of Sumner which is near Tacoma, about10,000 residents. Note that you can get this as fertilizer 100% strength or you can get a topsoil where they add sand and sawdust. Tacoma does the mix and makes a product called Tagro. Sumner is only 100%.
From the city it is free and there is a covered bin that is available 24/7 with a fresh pile. You can call ahead an have them load your truck with a bobcat or you can order a 10 yard dump for free if you're pretty close to the plant. It's a waste product for them so there is no charge.
You've got to understand that this is a sludge product so it will have a smell for a few days if surface broadcast but no smell when you till it in. Also, if you look real close you can see hair/lint that is not digestable and that may gross you out if you're weak in the stomach.
I usually bring empty garbage cans and fill them in the bed of the truck. The stuff is dense so you won't be able to move a full garbage can. Sometimes it is even pretty warm if it is fresh from the oven. You an spread it with a regular rotary broadcast spreader.
I forgot to add that municipal sludge/waste (here in Michigan) must be knifed in and/or injected underground, immediately and cannot lay fallow on the surface because of runoff considerations. That also applies to cattle manure in containment ponds, liquified for application.
