My understanding is that liner is always the answer to this, and that was my plan... but I have a bit of a problem.
I just bought a Jotul C350 fireplace insert which has a 6" flue. I did not first check the size of my fireplace's flue. It is insulated 11x6" clay tile.
It seems like it will be impossible to squeeze a 6" liner down that so my options for a liner would be to have an oval one made (like 3x the price) or use an undersized 5" liner which I imagine would still be a tight fit and is probably a terrible idea?
The manual says a positive connection is acceptable on external chimneys as long as the flue is smaller than 9x8". I assume 11x6" would be OK because the area is 66" compared to 72" for 9x8". Am I correct about this?
If I do this can I just use black stove pipe to make the connection? How far up the flue would it need to go? Would I need to make the block off plate myself or is there a way to buy those?
Any better ideas would be very much appreciated.
Thanks
Thanks
