Pressure regulator for Jotul gas stove
Steve Awodey
5
Pittsburgh
I am trying to get a Jotul GF 400 DV to work on a 100 lb. propane tank. What pressure regulator should I use?
The manual says it needs min. 12" WC supply pressure, but a standard low pressure regulator is preset at 11" WC.
A high pressure one is usually something like 0-20 PSI - which I guess is going to be way too high?
Does anyone have experience with this? Thanks for any advice!
Do you mean the regulator at the tank? If so, then just adjust it to the proper supply pressure for your fireplace.
