semipro
Based on this alone I'd replace the $35 pressure switch.But, again, it hesitated at 50 for a few seconds, made three light clicking sounds, with the needle jumping a little each time, before proceeding on up to 60.
Sage advice. I'll be doing that if it doesn't shut off at 60 here in a few minutes.Based on this alone I'd replace the $35 pressure switch.
Even if it shuts off at 60 that "chatter" would bother me a lot.Sage advice. I'll be doing that if it doesn't shut off at 60 here in a few minutes.
I think you are right.It appears to be wired correctly but I would plumb it different. If there's not a manifold then you should at least install another T for the switch then stub the end of the run at 4" or so. The reasoning is that the water has to go to end of the line then back up evenly to the gauge and switch. Putting a gauge or switch at the end of a run is bad for a few reasons. 1. Sediment can run directly to the orifice (everytime water hammers when you drain and refill) and 2. The end of the run will reach pressure before it backs up to the gauge. You'll have a hard time getting it set correctly. My guess is you plugged an orifice when you turned it back on.
If you are replumbing a tank manifold works best. It has the ports to put a pressure relief, gauge and switch as well as keep sediment flowing. It will work without a pressure relief but then there is nothing to protect components if the switch ever sticks. The problem when you run a 1/4" stub to hook everything to is that sediment never flows through and gets trapped and churned up every cycle. Eventually it will plug the gauge and switch. This pic is the best way to plumb.
Thanks, PB. I agree with your every word.Your experience is how the business model of many plumbing firms with the fancy trucks that you see on TV work. They can pretty well plan that if they get a foot in your door that plumbing systems are usually dated and there is rarely a quick fix. Once they are in the door pointing out all the problems they dont need to worry about competitive bids, they can pretty well write their own ticket under by bringing it back up to code and reliable. The home owner is usually desperate to get things working again so the contractor can sell them marked up parts and pieces that they carry on the truck of have back at the shop. In your case, I expect they would have just cut the incoming line, convinced you the pressure tank was old and prone to failure "soon" and dropped in a new tank and manifold then tied back into the lines going to the house. It would work and you would have a long term fix and big bill. If you shopped those parts on line or at Home Depot you would find a significant markup on parts and fixtures on top of a high hourly rate. And of course a week of two later your kitchen faucet would blow.
No doubt you learned a lot and what you spent is a small fraction of what you would have spend if you called the guy with the fancy truck. You also know more about the system and get the satisfaction of fixing it yourself and maybe can help someone out in the future. Sad to say there is whole generation of folks that werent brought up with the DIY background and all they can do is pick up the phone and live with the bills.
Thanks rwhite. Your guidance got me over the hump, and I really appreciate it.And just for future reference, whether its heating ducts, water lines or air pressure, anytime you need volume and pressure to be balanced you should never hook anything directly to a trunk line. It should always be T'd off of it. I've seen so many instances of folks trying to figure out why one sprinkler head gets all the pressure or one room in a house gets hotter than the rest. Only to find they hooked a vent or other device directly to the end of a run.
