Princess PE-32, my second year. Stove pipe, blower, stack height, shields, and damper type questions.
Inspect your cap. It may have a spark arresting screen that is plugging. Very, very common issue with your exact results. Sometimes difficult if not impossible to see from the ground.
May as well sweep the pipe entirely. Clogging/restriction can occur much quicker than one would expect.
Pull the connector pipe off the stove and clean out the stove around the bypass assembly and behind the catalyst.
likely you just need normal maintenance. Good luck.
I agree with the cap .
A leaking flue may exacerbate buildup because air being sucked in will cool flue gases.
Update: I arrived at the building yesterday, and I've attached a picture and video of the ouside when I'm reloading, and the cat is not engaged. While the comments might be 100% accurate (spark arrestor), this video to a person like me suggests there is little to no blockage. I also took a picture of the stove pipe from the bypass last night, and it was clean as a whistle. Now, in regards to the cap, I don't have a factory spark arrestor, but I have a bird arrestor home made cage, that probably has the same impact. The installer arrives tomorrow, let's see what he says. I like the comment about the leaking flue potentially sucking in cool air.
For anyone who says I should get rid of the cap, how am I supposed to deal with snow coming down into it when I am not around (only visit once per week). I get a lot of snow over the season, and the cap either will be on, or off permanently as I have no reasonable access to it at anytime of the year.
thanks,
RDP
  • [Hearth.com] Princess PE-32, my second year. Stove pipe, blower, stack height, shields, and damper type questions.
  • MVI_7100low.mov
    1.7 MB
Oh yeah, my money is in that silly screen being clogged. Can’t you just remove the screen and put the cap back on?
I can, but will require scaffolding to get up there to do it, and that is without snow to deal with in the spring. If I try to do it now I have tons of snow to move to put in the scaffolding. 20 feet deep under the roof at the moment! Very hard roof to deal with!
If I could push out the screen and the current cap from the stove that would do it, but then I would be capless untill the spring. I also could damage the roof when the cap and screen fall down after being pushed out.
I need a helicopter.......
RDP
RDP
Just find a kid with a drone. Fly up, get a good look and get some "possible" contributing evidence.
BKVP
Reactions: Tron
Final report: Stovepipe was clean, except at the very top where the homemade spark arrestor/bird screen was. Once the build-up was removed all issues with smoke coming into the room during reloading were resolved, and the box comes up to temp easier on initial start-up as well.
Interestingly, even with my pipe freshly cleaned I never hear any sucking/wooshing sound at the air intake on the back of the stove as others have reported. I guess my next project to add some height to the stack might provide the extra draft needed to hear that sound.
Q: My chimney cap is about 40 years old, my installer says there isn't really any improvements in tech over the years to have me go as far as considering putting in a new one. Would you all agree?
thanks,
RDP
Tech hasn't really changed, but the size of the mesh on the screen varies, get a cap with a 3/4" mesh, the finer ones plug up easier.
Reactions: Nelson
Just to confirm, due to creosote build-up issues on my current handmade spark arrestor/bird screen that it will be removed completely, leaving me just with the chimney cap, which I understand normally doesn't come with any screen at all. If I'm wrong about chimney caps and screens please let me know!
thanks,
RDP
My chimney has just the cap, nothing else.
Distance between the end of the flue and the cap is maybe 2-3" or so.
No screen is fine as long as your not worried about wildlife getting in. The main thing is your wood though, dry wood produces less creosote. My cap has about a 3/4 inch screen. I sweep once a year and never have come anywhere close to it plugging up. You need to burn dry wood and burn hot on startup/reload.
thanks,
RDP
My chimney cap came from Simpson (duravent) with no screen. I installed it and passed inspection. On a different chimney I bought a cap with the optional removable screen and it plugged up quickly with brown crunchy stuff despite using a very low emissions stove and very dry wood.
In my area the bird problem is nearly non existent but the clogging with creosote is a very real problem.
