Hello everyone,
I discussed this with Camfan by PM recently, and since it appears to be a somewhat unusal issue, I thought I would post to the forum to see if anyone else has had a similar experience.
I've had about a dozen or so fires in my Baby Bear so far this fall and after about the third use, I started seeing a few brown drips around the crown of the chimney that were coming from the underside/corners of the chimney cap. Since this year is the first time I've used a cap, I thought that this was probably somewhat of a normal condensation issue and figured I would simply keep an eye on it. However, soon after that, this same condensation began dripping from the cleanout door on the chimney and staining the block below it.
The liquid is basically like a brownish rusty water, that on a couple occassions has actually puddled onto the concrete base below the flue. It's not sticky, and it will wipe almost completely away if you catch it before it dries. The flue and stove pipe themselves are not showing any abnormal build up, thankfully, so I'm scratching my head at why this is happening. (It's also not a rain issue... When I first noticed it, we had not had rain for over two weeks.)
I've also been running the stove at, or above, proper temperatures and have let it run even hotter since noticing this hoping it would clear up, but the drips return each time I use the stove. The wood I'm burning is all hardwood that has been split and stacked for going on two years, so I don't believe that's the issue either.
I realize that with a small stove like the Baby Bear, an exterior masonry flue is not optimal, but the I.D. diameter of the flue is only 6 3/4, and it's about 15 feet tall from the thimble to the top, so it's not that terribly over-sized. The flue also has a very strong draw, even when cold. Upon starting a fire, I let the stove burn for 25 - 30 minutes with the draft cap nearly all the way open, then only turn it down to two turns open for the remainder of the burn. The only time I've set it lower is for overnight burns and still I've left it one full turn open. I've also experimented with and without a pipe damper to allow as much heat up the flue as possible. I know this may not be the best for conserving wood, but I just wanted to see what the effect would be on the condensation problem, but so far there's been no change.
Sorry for being so long winded, but this has me puzzled. I've burned several different types of stoves over the years on identical flues and never experienced this. I don't think I would as puzzled if I were having build up on the inside of the chimney, but the drips on the outside are something I haven't seen before. A certified chimney sweep was also unable to give me any solid answers, so any advice y'all can offer is appreciated!
(BTW, the flue is less than a year old and I have looked into lining it with S.S., but since it's barely over 6 inches as it is, I don't see that making much difference. That would also require milling out the clay tiles, so that a liner would fit, and I really hate to do that to a brand new flue!)
Thanks in advance,
Mark
Thanks in advance,
Mark
![[Hearth.com] Problem with condensation [Hearth.com] Problem with condensation](https://www.hearth.com/talk/data/attachments/123/123157-7b97c413150cbfe4494fcf232cfd229e.jpg?hash=H9JLQK9hJh)
Needless to say, I had the proper masonry installed around it and have since replaced the flue itself as I've mentioned in other posts.
