Step 1. Disassemble stove
Step 2. sand blast pieces
then I get lost.
Q1. Do I bolt it back together before painting it? or do I paint the pieces individually then reassemble?
Q2. What method of furnace cementing should I use to put the parts together, just get the joints after it's reassembled, or do i make a gasket of sorts and then bolt it together mushing the cement in between (does that make sense?)....
Q3. What grade of bolts would be best for this application, does it even matter? A lot of the ones I'm drilling out are what I'd call a countersunk bolt which requires a flathead screwdriver and sucks royally.
then I get lost.
