Quad Santa Fe help needed!!!!!
LancasterLake
9
Levering MI
We've had a Quad Santa Fe (freestanding) for many many years without much problem until last winter. The combustion/exhaust fan went bad and we purchased a "quick change" replacement (not original equipment) blower motor marketed as PP7620, and touted as way better than the original part. Initially after replacement everything was fine. Howevever we have increasingly since then had this problem with our stove: When running on high, the firepot fills with mostly-burned pellets, yet not quite ash, within just about 4 or 5 hours of cleaning the pot. This causes the dreaded stove rumble. When on low, there is not near as much build up in the pot; and medium there is some but not as much as on high. Prior to the fan change, we would only get this rumble after burning the stove for long periods without cleaning the pot. Now, we can't even sleep through the night without having to get up and clean the pot.
We recently replaced both the firepot gasket and the door gasket. The feed is set to the lowest possible. We have tried many brands of pellets, and our current brand is relatively small in size. Most folks have said that they have had great luck with this aftermarket replacement motor; but we can't help but think it is our problem. We wonder if maybe the motor is failing which is why it did not initally do this and continues to get worse; or if that motor and the Santa Fe just don't do well together. Anyone have any ideas?
Checked your vacuum switch (electrical connections, tubing, function)? If there is a hopper gasket, is it in good condition (not real familiar with your stove model)? Ash doors and burnpot door are closing well? Cleaning routine includes the combustion blower?
Usually smaller size pellet means a livelier, hotter burn. Piling pellets can mean an air issue but it sounds like you've replaced typical culprits.
The other end of the equation would be temperature sensing components... Have you tried testing/replacing the thermocouple?
Vacuum switch seems to be functioning perfectly. No hopper gasket. No ash pan gasket. Yes it would seem the smaller pellet would help alleviate the problem...my guess is it would be worse with smaller pellets. I have not checked the thermocouple although I woke up thinking about that component this am. However I'm not really sure how it would play a part in the cause and effect here? We leave the stove on always except to clean. So you are thinking it could be calling for more fuel than is needed? Here is a pic of the firepot after burning on high for only about 5 hours. Sorry it's sideways but you get the picture ;)
  • [Hearth.com] Quad Santa Fe help needed!!!!!
Looking at replacement combustion fans, I have seen the number of blades range from 7 to 11. I believe ours has 9 blades. If your 'universal' blower had a different number of blades, it wouldn't move the same amount of air assuming it ran at the same RPM. With less air, the burn would not be as aggressive and you wouldn't get the same amount of air through the burn pot, resulting in unburned pellets. I'm not understanding how a blower that is supposed to move a certain number of CFM can be touted as 'better'.
Do you still have the old blower? Hopefully, you do. Count the blades and then pull out the blower you're using and see if it's the same number of blades.
You say this happened right after replacing the blower so that sure looks like the culprit. It might be time to go with a new correct blower.
http://smile.amazon.com/Quadrafire-...bs_misc_4?ie=UTF8&refRID=0Y8BXVYD5H04WZ75MNZ7
Since you have had the stove for many years, I'm assuming you clean it correctly and keep all 8 small holes clean, make sure the dump valve is closed all the way and is not sagging down, the burn pot is tightly bolted in place and not cracked, ash is not being blown away from around the burn pot/floor interface, door gasket is tight and passes the dollar bill test, and the exhaust pipe/flue is completely clear and clean, and the wire mesh at the top of the flue is not clogged with wet ash.
When was the last cleaning on your exhaust system? tj accurate with the replacement blower - may be close but not the right one;hm. Cleaning the system may perk it up in the short term...
Is this the blower? http://www.ebay.ca/itm/QUADRAFIRE-C...ER-MOTOR-GASKET-PP7620-812-4400-/161189604544
Quick Change" Exhaust Blower Motor Assembly
Ceramic Gasket Replacement
Impeller Blade 4.4"6" Mounting Plate with 2 sets of mounting holes
All assembled (See pictures)
MOTOR SPECS:
115 Volts - AC
AMPS - 1.0
RPM - 2900
2- Male Spade terminal leads exiting the motor wires.
1- Ground wire on motorBall bearing motor (Doesn't require oil)
Made by FASCO in North America
5/16" dia. stainless steel shaft
This blower seems to be carried by many stove part suppliers as the replacement blower 812-4400 - 4 or 5 different suppliers.
Sounds like an issue with the new exhaust fan like tj says. One thing to look at is unplug stove and plug back in, Then see how many times the blue light blinks. kap
Reactions: LancasterLake
Cleaning done VERY regularly. Exhaust cleaning done at the beginning of this heating season. Both of those links go to the same aftermarket piece that we bought. They make it look like its the Quad part (812-4400) but it is not. I have not been able to find the specs on the factory part to compare the RPMs. No we don't have the original part unfortunately.
The OEM specs out as follows:
115v 60Hz 29W at .48 Amps. 2900 RPM Class H motor
We also carry that same aftermarket blower for the stove that you have, the PP7620, although we very clearly indicate that it is an aftermarket part and not OEM. The motor has been tested very thoroughly by independent labs to make certain it closely matches the OEM part. It is not a case of grab some motor that is close enough, slap it on a plate and call it good but one that has been tested and vetted. I would recommend checking your feed rate timing you are getting from the stove which would be .
9 sec LOW //// 1.6 sec MEDIUM //// 2.2 sec HIGH for auger on time.
If the stove is burning improperly and the feed rate is good I would contact the company you purchased it from and see if they have any suggestions or would be able to warranty on the blower for you.
Quad factory exhaust fan is 2900 rpm
Thermocouple only senses the fires temp, and tells stove it can feed, it doesn't regulate the feed.
Do any of you Quad guru's know how many fan blades are on the stock fan? That would give the OP a way to check his new fan against the old.
Ding Ding Ding. We have a winner! lol
Reactions: tjnamtiw
How clean are those lower air holes?
Is this burning the same pellets that you set your flame height with?
The only time I get the 'rumble' is on initial start up when a lot of pellets have been fed into the burnpot and the fire is quite intense and high. You will feed more pounds of pellets when they are small. An important answer is what kap said > how many flashes do you get on the control box when you first plug it in?
If it's set correctly, then it must be an air issue. You replaced the door and burn pot gaskets. Does the door now pass the dollar bill test? How is your exhaust routed? How do you clean it? Do you remove the exhaust fan when doing the yearly cleaning? Is there a T in the exhaust? When you have the fan out, do you clean the stove's internal ducting that goes up at an angle to the exhaust outlet?
Looking at the picture, WHERE IS THE FLAME? There is DEFINITELY an air flow issue. Either your exhaust is plugged or the fan is loose on the motor shaft or the motor is shot. Do you have a screen on the end of your flue that could be plugged with ash?
Lower air holes are open. Except of course when the mostly burned pellets yet not quite ash build up in the pot and cover the holes which is what causes the rumble.
Yes, these pellets are the same. When burning with fan on high the flame is almost too big yet the feed adjustment is closed as far as possible and that is the only adjustment on our stove. Burning at low and medium the flame is closer to correct size and color but of course not being on high it's certainly not putting out as much heat.
The picture was purposely taken after turning the thermostat down and the flame went out, so that I could show the buildup in the burn pot. The exhaust is not plugged, the flue is not plugged. The exhaust goes straight out the back, no 90s so it's very easy to keep clean so we do it regularly. The fan is not loose but yes the motor probably has problems. It's less than a year old though and my issue is that it's under warranty however we have to send it in for their determination of problem and replacement, fixing, or whatever they decide. We would be with out a stove during that time. My thought is if I have to buy yet another new fan, if all signs point to this fan being the problem I should just buy the OEM Quad fan.
Exactly when we used to get that rumble...only on start up with a temporarily large flame.
The blue light flashes 6 times.
The exhaust goes straight out the back, no 90s no Ts. Yes it gets cleaned very regularly because it's pretty easy to get to. The exhaust fan has been cleaned as has all the internal parts of the stove and the freshh air intake tube. Yes those gaskets were just replaced however the door gasket doesn't seem right. When I checked it initially I only checked the corners thinking thats where the issue would be, and they were tight, but the center top is not. We are right now figuring out what was done wrong, and looking to redo that before ordering a new fan.
Are you saying that on high the auger would drop pellets every 2.2 seconds? It currently drops every 4.5 seconds and THAT seems like too much and also seems like MORE than it used to drop when the stove ran better.
THese are "on" times. This is how long the auger is on feeding.
