Hi All,
My Quadra-fire Castile will not feed. I had a tech come out and diagnose as I am unfamiliar with this stove being that the stove was installed prior to me buying the home.
He said that my auger feed motor was bad...
I replaced the part and still no feed.
I referred to my manual and it said to replace snap disc 2. I did so. Still no feed.
I went back to the manual and it said possible bad vacuum switch. I replaced that and still no feed.
At this point, I am pretty frustrated. The red light comes on when i plug in the machine after the blue lights blink a few times (I believe it is three cycles of four blinks), I adjust the remote thermostat so that the stove calls for heat, it clicks but no feed. The glow bar heats up and still nothing. The glass door is secure, and all covers are in place I thought a possible feed jam, so i emptied the unit and manually turned the auger and it fed. with no problem.
Any advice would be greatly appreciated. I am new to the appliance and certainly don't want to break anything or replace more parts that I now see that I didn't have to.
Thanks,
Keith
Thanks,
Keith
It sounds like a car dealership where you just throw parts at it and hope it works.
![[Hearth.com] Quadra-Fire Castile troubles... [Hearth.com] Quadra-Fire Castile troubles...](https://www.hearth.com/talk/data/attachments/144/144226-caf2ef3dd066b0ba7e2450a110563b5c.jpg?hash=Qh2zEdF4RZ)
![[Hearth.com] Quadra-Fire Castile troubles... [Hearth.com] Quadra-Fire Castile troubles...](https://www.hearth.com/talk/data/attachments/144/144227-4d7745bc338311c82695947c1397cd10.jpg?hash=IJu_5D8tBd)
Or the thing is plugged up with ash? Anything causing an obstruction to the combustion blower's ability to move air through the stove and venting (especially if you're at or above your max EVL recommendation) can affect your vacuum issues, which in turn can shut down the auger function.
